Thread: Blower Moter blows intermittently
Results 1 to 19 of 19
  1. #1 Blower Moter blows intermittently
    Oct 2013
    Milverton, Ontario
    I have an 05 Grand Prix GT, and I have had some trouble with the blower motor. I have replaced the resistor 3 times now, and have had the capacitor installed that absorbs any spike in voltage from the windshield wiper switch. Now the blower motor runs, but not consistently, like on for 3 seconds and off for 30 seconds. Any idea where the problem might be? I hope its not the resistor again because they run at $100 here in Ontario.
  2. #2 Re: Blower Moter blows intermittently
    Maybe the motor itself is on its way out?
  3. #3 Re: Blower Moter blows intermittently
    Oct 2013
    Milverton, Ontario
    I just talked to my mechanic and he says he rarely sees the blower motor go bad. He thinks its the resistor again.
    Any help from anybody?
  4. #4 Re: Blower Moter blows intermittently
    Banned
    Oct 2013
    Moorhead, MN
    Um. If you replaced the same part more than one time, let alone 3,you need a new mechanic.
    That being said, there's a TSB for this, or you have a short somewhere
  5. #5 Re: Blower Moter blows intermittently
    Oct 2013
    Milverton, Ontario
    Quote Originally Posted by Thompsju View Post
    Pardon me, but what's a TSB ?
  6. #6 Re: Blower Moter blows intermittently
    My blower just recently quit. Swapped a new one in and boom heat again.
  7. #7 Re: Blower Moter blows intermittently
    Banned
    Oct 2013
    Moorhead, MN
    Quote Originally Posted by Jonk1086 View Post
    "TECHNICAL SERVICE BULLETIN"
    It draws out a f*** up in mass manufacturing that GM refuses to fix, but they are nice enough to tell you how to fix it, on your dime.
    Your "mechanic" obviously didn't get the memo... Which is very unprofessional on his part.
    Start going somewhere else.
    I hope you didn't get charged for the 2nd or 3rd replacement...
    And who in their right mind would suggest a 4th?!?!?
    http://m.carcomplaints.com/Pontiac/G...rix/2005/tsbs/
  8. #8 Re: Blower Moter blows intermittently
    Oct 2013
    Milverton, Ontario
    My mechanic already has done all that the service bulletins advise, and the resistors still keep going.
    Maybe a non-Chevy car would be the best fix.......
  9. #9 Re: Blower Moter blows intermittently
    Maybe the right part would be the best fix
  10. #10 Re: Blower Moter blows intermittently
    Banned
    Oct 2013
    Moorhead, MN
    Your mechanic is a dipsh##.
  11. #11 Re: Blower Moter blows intermittently
    Dec 2012
    Where 4T65E's were born
    The resistors will blow often if the blower motor is going bad. It may have a shorted commutator segment in the motor, causing it to draw higher than normal amperage, burning resistors out.
    Sold.
  12. #12 Re: Blower Moter blows intermittently
    Oct 2013
    Milverton, Ontario
    Just thought I'd tell you all, I replaced the blower motor with another used one and bought another blower motor resistor off Ebay and now everything works again, except the air never gets that warm. I'm going to get the local garage to flush the heater core, as that fixed the problem last time.
    Any ideas or suggestions?
  13. #13 Re: Blower Moter blows intermittently
    If you have a pair of pliers and a garden hose you can flush the heater core yourself.
  14. #14 Re: Blower Moter blows intermittently
    Aug 2011
    'Merica
    Would you want to flush it in the winter?? Remember he is from up North.
  15. #15 Re: Blower Moter blows intermittently
    Dec 2012
    Quote Originally Posted by Below Average Joe View Post
    Nothing wrong with that, just don't leave water in it.
    Sold.
  16. #16 Re: Blower Moter blows intermittently
    You want to flush it to have heat for the winter
  17. #17 Re: Blower Moter blows intermittently
    Feb 2013
    37.295091, -121.930053
    heat is good just make sure you dont use water this time of the year.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  18. #18 Re: Blower Moter blows intermittently
    the little bit of water left in the heater core isn't gonna be enough to dilute it much.
  19. #19 Re: Blower Moter blows intermittently
    Oct 2013
    Milverton, Ontario
    well, to end the argument the garage pulsed fluid through it back and forth to break off the whatever might be in there, and said he got quite a bit out of it. And now it heats like crazy!!! And that's a good think because we've already had snow a few times.
  1. Heater blows cold when set to hot and blows hot when set to cold??????
    By Markgp in forum General Grand Prix Discussion
    Last Post: 10-29-2013, 07:38 PM
  2. HUD working intermittently ('97 GTP)
    By Powertrike in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2010, 09:07 PM
  3. Where do I hook up an Oil Gauge at on the moter?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-02-2010, 12:26 PM
  4. HUD and GPS going out intermittently?
    By Jas0n in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2010, 08:22 PM
  5. Key intermittently won't come out of ignition
    By atclarkson in forum General Tech Discussion
    Last Post: 06-09-2010, 09:47 AM
