Thread: how to change a climate control switch
Results 1 to 4 of 4
  1. #1 how to change a climate control switch
    Nov 2010
    Rogersville
    Need to change the blower switch for ac/heater how do I do this. thanks
  2. #2 Re: how to change a climate control switch
    St. Louis
    Switch, as in the entire unit? Or just the part on the HVAC unit that controls the blower?
  3. #3 Re: how to change a climate control switch
    Nov 2010
    Rogersville
    Quote Originally Posted by FordMan77 View Post
    just the hvac unit
  4. #4 Re: how to change a climate control switch
    St. Louis
    I'm not sure you can change just 1 part on the HVAC head. Pretty sure it's all or none. If you plan on changing the head then it's pretty simple. Just remove the dash surround, remove the screws holding the hvac head into the dash and then remove any wires/vac. connections on the head. Install new one and test BEFORE you put the dash surround back on. No need breaking clips by taking it off more than neccessary.
  1. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  2. Dual zone climate control - cannot switch modes (defrost only)
    By alacran in forum General Tech Discussion
    Last Post: 01-03-2009, 09:50 AM
