Thread: rain leak 3" on floorboard
Results 1 to 6 of 6
  1. #1 rain leak 3" on floorboard
    Aug 2012
    Tukwila, Washington, United States
    i know how to fix it now but how to you get the water out?
    i tried towels but there's still so much water on passenger side and the car smells like something died there.
    do i need to open the whole carpet? it cost so much..
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: rain leak 3" on floorboard
    Omaha, NE
    Are you saying that theres 3" of standing water on your floorboard?
  3. #3 Re: rain leak 3" on floorboard
    Aug 2012
    from the bottom. but not anymore.
    i used towels to soak it out.
    its still really wet when you press on it your hand get wet. nd it feels like its ruining everything underneath.
    its losing the shape of a floorboard.
    what should i do?
    ahhhh so many problems with this car.
  4. #4 Re: rain leak 3" on floorboard
    Omaha, NE
    I would reccomend carpet an insulation replacement. Mold could build up between the two and end up causing you to get sick.
    If you don't want to do that, put a fan in the car, aimed at the wet area overnight, or for at least 12 hours. Spary the affected area heavily wth fabreeze every few hours if possible. That should help take the smell out without a "cover up smell" for too long.
  5. #5 Re: rain leak 3" on floorboard
    Nov 2012
    Madison
    find some one with a dehumidifier, set it in your backseat maybe on some plywood to keep it level. That will dry it out completely. If your still afraid of mold, you can mist it with vinegar,since bleach would F it up. Car might smell kosher dill for a few days.
  6. #6 Re: rain leak 3" on floorboard
    A carpet wet vac is the best thing to use. Everytime I clean someones car or buy a new on for myself I use it.
    Its a small unit that has a spray gun with the vac hose it aswell, I spray the carpet with the cleaner, scrub it in and vacuum up all the water and its dry within hours.
  1. Replies: 6
    Last Post: 12-28-2012, 09:13 PM
  2. Antifreeze Leak From "Somewhere"
    By sdavis11b in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2011, 08:31 AM
  3. Help with rain leak
    By redrivergar in forum General Tech Discussion
    Last Post: 02-06-2011, 02:44 PM
  4. Oil "Leak"/Anti-freeze dump
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 08:06 PM
  5. "Fixed" the passenger side water leak, still wet!
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 07-24-2008, 06:28 PM
