Thread: Water Pump?
Results 1 to 15 of 15
  1. #1 Water Pump?
    SE Level Member Lowdown112's Avatar
    Dec 2012
    Louisville
    How would I know if my water pump is going bad?
    99 Black GTP w/a few cosmetic mods.
    01 Ninja 250 w/a few cosmetic mods.
    5 Month Old Little Boy. Stock w/full straightpipe digestive system and @ 140000 watt crying amp.
  2. #2 Re: Water Pump?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    It is leaking out of the holes in the housing, it is making noise, or you suspect low coolant flow. Why do you ask?
    97 Bonneville SE Not so much a 97 anymore
  3. #3 Re: Water Pump?
    Dec 2012
    Louisville
    It has low coolant flow...I think, it is overheating then going back to being cool if i go about 80. About a month ago I thought it was my rad. Replaced it brand new thought it was fixed (i did have a rad leak so that was fixed but still kept overheating) so thats why I think my waterpump is bad. Plus I hear a whine and im pretty sure its not my supercharger. Not 100% sure how they work, but I hear a whine when im going like 20. And my engine temp starts to rise.
    I live here. DirtDog's Avatar
    Jun 2012
    Overheating as well can be a tale tale sign
    Sent from my DROID RAZR using Tapatalk 2
  5. #5 Re: Water Pump?
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    as marines542 said, overheating can be a sign, but often, you can tell before it gets that hot. If youre cruising and your car is running a few degrees higher than yesterday, or if it takes longer for the gauge to drop once the stat opens or the fan kicks in, that can be a sign.
    I drove for most of the summer with the pump on the way out, i noticed the car was running closer to 210 than the usual 188-192 but i figured it was because it was over 80 outside. The day before it failed it had been running 215-220. When it finally went, i had steam, no power (because the belt got wet and was not running the alternator or p/s pump), and it got up to 230 and the heat was blowing cool. I made it into a Wendys parking lot and shut er off before it reached the red zone.
    I watch the temperature like a hawk. Thats why I dont understand some of these new eco-box cars dont have a gauge, just an idiot light. If its 65 outside and at speed you normally run at 190 (give or take ten degrees) and it seems like youre staying closer to 200-205, thats your early warning that something is amiss. Granted 205 is not outside the normal range, when you know your car, you know when she's not feeling well.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  6. #6 Re: Water Pump?
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    I know how you can tell!!! but don't know how to explain, lol it makes a weird noise when is bad
  7. #7 Re: Water Pump?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by Lowdown112 View Post
    Go out in the morning and look under the car, if you see a puddle that gets bigger each day, that is bad.
    Or, lean over the belt while car is running.
    If it is spraying water up at you, that is the pump weeping on the belt.
    1997 Red GTP 182000 miles stock
    Jun 2012
    It could be the water pump. Also the PS pumps are known to have a wine. Mine does everyone and then. Especially when cold. The water pumps are very easy to change out and only require a couple hours max
  9. #9 Re: Water Pump?
    Dec 2012
    Louisville
    Hmm...but my power steering is has been fine? Ill replace the water pump if that doesnt fix it ill replace the Lim if that doesnt get it im selling :P
  10. #10 Re: Water Pump?
    Jun 2012
    take a video of the whine. ive never heard of a water pump squeak. does the whine change it sound with the engine rpm's
  11. #11 Re: Water Pump?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    The whine is the ps pump. Try changing the fluid. Turkey baster will do the trick.
    Jun 2012
    Quote Originally Posted by GTP in RTP View Post
    My thinking exactly. Just cause they wine doesn't mean their bad cause mine always wines
  13. #13 Re: Water Pump?
    Dec 2012
    Louisville
    Alright ill take a vid of it on my way to work and post it when i get off.
  14. #14 Re: Water Pump?
    with the car off, with two hands, grab the water pump pulley, push and pull the pulley, if it has play and moves, the pump is bad. you can do this with the belt on.
  15. #15 Re: Water Pump?
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    I like the CYA warning of making sure to do this with the car off...lol
    RE the power steering pump - thanks for solving that mystery for me, guys. I've had my GP for a year now, and it's always had that whine to it that kinda followed the RPMs. I wasn't ever worried about it, just curious. Now I know what it is.
  1. water pump
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2012, 07:57 AM
  2. Water Pump
    By blaqdiamondz46 in forum General Tech Discussion
    Last Post: 11-11-2011, 05:25 PM
  3. Water Pump
    Last Post: 11-11-2011, 03:29 PM
  4. Water pump HELP
    By cincygoat in forum Off Topic Discussion
    Last Post: 06-26-2011, 06:57 PM
  5. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
