Thread: Coolant Leak Please help!!!
Results 1 to 11 of 11
  1. #1 Coolant Leak Please help!!!
    Jan 2013
    Oshawa, Ontario, Canada
    I have a 2001 Grand Prix GTP 3.8l SCI have a coolant leak between the engine and transmission could anyone point out to me what it could be? I am new to this engine and have no clue? Intake gasket?, Crank seal? frost plug? There is no sign of a leak on the top of the engine. I have changed the elbows on the tensioner. Please if anyone could help!
  2. #2 Re: Coolant Leak Please help!!!
    antioch ill
    most likley the lim gasket
  3. #3 Re: Coolant Leak Please help!!!
    thermostat housing maybe. Take a pic of where it's leaking.
  4. #4 Re: Coolant Leak Please help!!!
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    i bet its the lim gasket.. mine also leaked on that side
  5. #5 Re: Coolant Leak Please help!!!
    Kansas
    Step one... clean area.
    Step two... inspect and give us a better idea.... or even better pictures!
    LIM gaskets, t-stat housing, LIM coolant passage gasket.... take your pick.
  6. #6 Re: Coolant Leak Please help!!!
    are you sure its coming from between the engine and trans? if so that would be a freeze plug, and your either pulling the engine or tranny to change it.
    or it could be a heater core hose leaking, but that would leak down the fire wall behind the tranny and hit the down pipe.
  7. #7 Re: Coolant Leak Please help!!!
    Aug 2012
    Tukwila, Washington, United States
    It's the lim/uim gasket.
    Thats what I have right now caused my car hydrolock
    u better fix it ASAP
    Grand Prix gt 1999 v6 3.8L coupe.
  8. #8 Re: Coolant Leak Please help!!!
    Uim you mean sc?
  9. #9 Re: Coolant Leak Please help!!!
    Jan 2013
    Where is this lim gasket does anyone have a picture? Is that a lower intake gasket?
  10. #10 Re: Coolant Leak Please help!!!
    Lower intake manifold gasket. Take a pic of where it's leaking.
  11. #11 Re: Coolant Leak Please help!!!
    Jan 2013
    There is no sign of coolant on the top of the engine when I pressure test it the Coolant system the coolant leaks out from the bottom of the engine where the engine and trans join.
  1. Coolant Leak?!?
    By selym17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2013, 02:42 PM
  2. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  3. coolant leak
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-15-2011, 07:44 PM
  4. My new coolant leak
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 08:31 AM
  5. Coolant leak?
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 01:59 PM
