Thread: to mod or not to mod
Results 1 to 19 of 19
  1. #1 to mod or not to mod
    Jan 2013
    michigan
    i have a 1999 grand prix gtp coupe has minor rust but i was wondering if i should lightly mod it or not? the engine has 219k on it how much of a factor would that be? it's throwing a couple codes on the odbII scanner.
  2. #2 Re: to mod or not to mod
    Jan 2013
    Tolono IL
    since its a GTP i would lol but what all were u thinking about mods?
  3. #3 Re: to mod or not to mod
    Florida
    What codes are being thrown? Obviously you want to do all maintenance before you start modding.
    Make sure the engine is up to par before you start throwing stuff at it that is going to make it work harder.
  4. #4 Re: to mod or not to mod
    Bunnell, FL
    throw on a 3.0
    blow the motor
    make an epic rebuild that makes no sense
    blow it up on the dyno
    don't say anything
    profit
    I'm a Sex Offender
  5. #5 Re: to mod or not to mod
    Mar 2012
    NC
    Only an idiot would mod an engine with 219k...oh wait...I am that idiot.
  6. #6 Re: to mod or not to mod
    Bunnell, FL
    ^^^ i hit 250k before i most likely cracked the flex plate
    before i gave up and bought a brand new car
    I'm a Sex Offender
  7. #7 Re: to mod or not to mod
    Jan 2013
    michigan
    i was thinking a fenderwell intake, 180 degree t stat, 3.4 pulley, autolite 104 plugs, headers, and a pcm. the previous owner said it had a borla exhaust installed on it but i don't really believe that. as for the codes it is throwing they are P0401 and P0442
  8. #8 Re: to mod or not to mod
    Bunnell, FL
    3.4 might be pushing it
    with that many miles i'd really suggest 3.6 unless you add rockers and an aeroforce to scan
    I'm a Sex Offender
  9. #9 Re: to mod or not to mod
    With those kind miles I would look around and get a lower mileage block and then starting modding that one and then drop it in. Minimum downtown and no rush to finish it. If I could do it all over again of would of done that instead of modding my current one and having so much downtown and avoiding the PIA.
    04 Comp G.
  10. #10 Re: to mod or not to mod
    Texas
    Seriously, your car must have been a POS to begin, was not taken care of, or you weren't installing modifications correctly. Case in point there are more people with high mileage cars than low mileage cars on this site that mod with no problems and don't have that downtime you are talking about.
    OP get the codes resolved then start modding and enjoying the car. I've got over 200K on mine with a healthy dose of mods and she's still running strong.
    85 Corvette
    01 TA
    03 Z06
    SE Level Member Adam D's Avatar
    Jan 2013
    grand rapids mi
    Quote Originally Posted by locuno1 View Post
    I got 230 k on mine im about to start a lim gasket today i think then go from there with bolt ons if it blows then i got bolt ons for my next motor right
    Sent from my SPH-L710 using Tapatalk 2
  12. #12 Re: to mod or not to mod
    Nov 2011
    NY
    Resolve codes... Then basic maintenance items, lim, tranny, etc. then headers, tune, then mod away!
    But first and foremost so you aren't all over the place spending unwisely, then spending again... Research what you want from the mods or how far you wanna go or spend, make a plan and then go for it!
    Good luck!
    Quote Originally Posted by txslow6 View Post
    Not at all ask anyone who has seen it. Let me elaborate I've done headers, cam,lim,heads etc all at different times. If I could do it all over again I've would have done it all at once to avoid having to take everything apart multiple times in my driveway. Working 50 hours a week and being in school as well as having custody of a 1 year old neice. Time wasn't on my side to say the least. Everything has been installed correctly I do my research before I buy or attempt anything and take my time to ensure user error is avoided. That being said if I was able to get another motor from the junkyard etc I would of just built the motor and dropped it all in and called it a day. Thanks for assuming.
    04 Comp G.
  14. #14 Re: to mod or not to mod
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Yeah, I would get the codes sorted out, do basic maintenance like plugs wires, fluids if necessary and then have at it for modding, mileage on these blocks is just a number really. I took mine apart at 190k to port the heads and lim while doing LIM gaskets and sure enough I still had the crosshatching on the cylinder walls and all of the valves still rubbed dye off when checking for proper seating. No reason this shouldn't keep running 12's until the body rots out or I decide to inter-cool it and make it run 11's.
    Quote Originally Posted by addzradd View Post
    Look at DSluts he has 200k plus modded rust and all and it still doesn't want to die lol. Yes address the maintenance items first and of course the codes and modify it lightly and go from there.
    04 Comp G.
  16. #16 Re: to mod or not to mod
    dsmuts Mod the piss out of it and make it snap in half from rust
  17. #17 Re: to mod or not to mod
    Kansas
    Come on guys... be realistic.
    Big ass snail.... piping/manifolds..... 23lbs of boost.
    Blow engine, and rape the transmission.
    Start all over on a different platform.
    Profit.
  18. #18 Re: to mod or not to mod
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    P0442 - check your gas cap.
  19. #19 Re: to mod or not to mod
    Jan 2013
    michigan
    Quote Originally Posted by bsharpminor View Post
    yup bought a new gas cap yesterday installed it and cleared the codes before work light came back on on the way home from work last night so i checked today and a faulty gas cap was the culprit. One code down one to go
mod
