Thread: Fbody brake swap questions...
Results 41 to 60 of 62
  1. #41 Re: Fbody brake swap questions...
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    It's not really worth the time and effort and parts search to rebuild f body calipers for the price you can buy remans for.
    But if you really want to here's a link for a good how to. www.InstallUniversity.com
    Buffalo
    Quote Originally Posted by 99PGPGT View Post
    I can guarantee you will not find a late 4th gen in the junkyard
    Lmfao. Are you high when you post?
    PayPal me $20 and I'll snap a pic of a row of 4th gens in my local pick and pull
  3. #43 Re: Fbody brake swap questions...
    Feb 2010
    TN
    Reason I asked is the yard by me has two of them
  4. #44 Re: Fbody brake swap questions...
    id buy from JY, take them apart, get them power coated, then rebuild them. rebuilding them looks easy.
  5. #45 Re: Fbody brake swap questions...
    Feb 2010
    TN
    Quote Originally Posted by 231FUN View Post
    I just did a parts check here if I have to replace pins $8.99 (pair) and boots 12.69 (all four) plus the calipers from the yard 17.92 (pr) caliper brackets 4.98 (pair) for a total of $44.58 remans come to $107.98 (pair with bracket) I dunno it seem like you are getting one for free and then some unless the rebuild is a real bear I will check that link but thanks
  6. #46 Re: Fbody brake swap questions...
    Feb 2010
    TN
    ok am I missing something I can't find a caliper rebuild in that link
  7. #47 Re: Fbody brake swap questions...
    www.InstallUniversity.com there ya go, its easy looking.
    wont work, go top left, to install docs. then scroll down to brake caliper rebuild
  8. #48 Re: Fbody brake swap questions...
    Feb 2010
    TN
    Thanks scotty your right does not look too bad a job just a little patience it would seem
  9. #49 Re: Fbody brake swap questions...
    i was pricing up a parts list and found this
    Front Brake Calipers Drilled Slotted Rotors Ceramic Pads Covers Left and Right | eBay
    anybody heard of these or heard o anybody using these?
    SMGPFC Member #10
  10. #50 Re: Fbody brake swap questions...
    always thought the Callahan name was made up for the movie "tommy boy" lol
  11. #51 Re: Fbody brake swap questions...
    i would replace the pads if those are cheap junk.
    but that looks like it comes with everything you'll need minus the brake lines and the bracket bolts(but cant you reuse the stock ones?)
    SMGPFC Member #10
  12. #52 Re: Fbody brake swap questions...
    no caliper brackets. and i cant see if they come with the bango bolt or not.
    can you find any reviews on them? they dont LOOK bad really.
  13. #53 Re: Fbody brake swap questions...
    in the pics it shows the brackets, so basically just a hardware kit is what you would need
    SMGPFC Member #10
  14. #54 Re: Fbody brake swap questions...
    i stand corrected on that, your right, looks like you need the caliper bolts only and the lines, still looks like a good deal.
    or tap the brackets and use the stock w body bolts.
  15. #55 Re: Fbody brake swap questions...
    Feb 2010
    TN
    I though it from "Dirty Harry"
  16. #56 Re: Fbody brake swap questions...
    Quote Originally Posted by Logan541 View Post
    not quite the same thing lol
    one carry's a big gun, the other's carry brake parts lol
    but tommy boys dads company did sell Callahan parts. the whole show was about selling the new line of brake pads.
  17. #57 Re: Fbody brake swap questions...
    Feb 2010
    TN
    Oh, thanks scotty
  18. #58 Re: Fbody brake swap questions...
    Feb 2010
    TN
    just a thought if mycars abs and tire pressure senors 97 gt does the donora car have to as well
  19. #59 Re: Fbody brake swap questions...
    your car only stops better. the abs dont care about the brakes, the sensor is in the wheel hub.
  20. #60 Re: Fbody brake swap questions...
    Feb 2010
    TN
    Thank you
  1. bolts on fbody brake upgrade
    By foursixer in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2011, 04:16 PM
  2. Fbody/C5 Brake Upgrade Help
    By arc in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 12:05 AM
  3. fbody brake question
    By silvermistgt2002 in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2009, 11:12 PM
  4. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
  5. fbody brake upgrade
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2008, 09:59 AM
