Thread: Fbody brake swap questions...
Page 4 of 4 FirstFirst ... 234
Results 61 to 62 of 62
  1. #61 Re: Fbody brake swap questions...
    Feb 2010
    TN
    calipers from a 2001 camaro will fit the same way correct? (I got a chance to get a set from the yard)
  2. #62 Re: Fbody brake swap questions...
    Quote Originally Posted by Logan541 View Post
    yes. 98-02
    make sure you take the banjo bolt from the brake line, you'll need it. and all bolts and hardware.
    truth is you can just remove the caliper bracket bolts, and lift the whole set up and off the rotor, id break the caliper bolts loose first as they can fight a bit when off the car.
  1. bolts on fbody brake upgrade
    By foursixer in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2011, 04:16 PM
  2. Fbody/C5 Brake Upgrade Help
    By arc in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 12:05 AM
  3. fbody brake question
    By silvermistgt2002 in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2009, 11:12 PM
  4. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
  5. fbody brake upgrade
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2008, 09:59 AM
