Thread: Supercharger porting and LIM
Results 1 to 20 of 30
  1. #1 Supercharger porting and LIM
    SE Level Member 2000supercharged's Avatar
    Aug 2012
    unitedstates
    Okay just simple question in progress of getting tune and some other stuff i know ZZP ports superchargers and lower intake manifolds and throttle bodys how is there porting? from some of the you guys that have delt with their quality do you recomend them or who would you recomend. or should i wait a little bit to port or what ?
    2000 GTP 107,000 miles pace setter headers 3.5 pulley, CAI intake and methonal injection and full exhaust
  2. #2 Re: Supercharger porting and LIM
    antioch ill
    do it yourself with a dremel tool or if you can get your hands on a mill even better yet
  3. #3 Re: Supercharger porting and LIM
    You'll need a tune when porting the TB.
    Otherwise, you can port the blower and LIM yourself in an afternoon, it's pretty easy. There are tons of threads here on it.
  4. #4 Re: Supercharger porting and LIM
    Don't touch the throttle body unless you can do a custom tune.
    Just make the triangle on the blower bigger, get rid of the 2 humps.
    The intake manifold does not need to touched unless you want to open it up for a intercooler setup.
  5. #5 Re: Supercharger porting and LIM
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    You do not want to make the triange any bigger, but getting rid of the bolt extensions is good, also gasket matching the LIM is a good idea mine were off over 1/4 inch in some spots with the new gm metal gaskets.
    The TB is something you probably wouldn't tackle at home outside of knife edgeing the throttle blade and getting rid of a good chunk of the bar on the blade to open it up, but you can always go with a northstar setup easily if you want.
  6. #6 Re: Supercharger porting and LIM
    As well..many of us are sitting on a ton of parts that we'd sell super cheap. I know that I have a Gen 3 M90 and intakes laying around, Intrigue98 and Dtrick do as well...that's just three out of the forum.
    Get spares cheap and have fun with them.
    The Boss Iceman6669's Avatar
    Jun 2011
    How much for an L67 LIM??
    2011 F-150 Yote powered
    Jun 2011
    Just a pic of my ported blower.
    Supercharger porting and LIM Attached Images
  9. #9 Re: Supercharger porting and LIM
    Quote Originally Posted by Iceman6669 View Post
    I think I have one laying around
  10. #10 Re: Supercharger porting and LIM
    stop showing people this. your port is too big. you enlarged the triangle.
  11. #11 Re: Supercharger porting and LIM
    May 2008
    Schuyler, NE
    Yup, looks like you screwed that blower up.
    OP, ZZP does a great job at porting blowers and LIM's.
    Jun 2011
    Well.. Explain HOW I screwed up the blower... Still make 7.5psi... And only see 2* KR at the shift in second... Sounds ok to me...
  13. #13 Re: Supercharger porting and LIM
    you should have just put a bevel on the outlet and left it the same size. it's matched to the rotor angles and now you've changed it.
    Jun 2011
    Well what I did was copy intense's port for the top of the triangle and ZZPs for the bottom. I kept the angles the same in the corners. And didn't open up the triangle past the ends of the rotors.
  15. #15 Re: Supercharger porting and LIM
    May 2008
    Schuyler, NE
    And, now you know why people make fun of Intense's blower port jobs.
  16. #16 Re: Supercharger porting and LIM
    Feb 2010
    Cleveland
    Wow, whatever you do do not follow that guy's port job. the only thing you really want to do the the triange near the top is get rid of the little casting burrs on the edge.
    Jun 2011
    Don't do it if you don't want.... All I can tell you is mine works...
  18. #18 Re: Supercharger porting and LIM
    May 2008
    Schuyler, NE
    You have no data to prove that it works.
    Jun 2011
    What kinda data u want? I have boost #s and KR #s and MAF lbs/min numbers... What more do you need??
  20. #20 Re: Supercharger porting and LIM
  1. Porting Your Supercharger
    By kfish in forum How To Write-Ups/Tech Tips
    Last Post: 02-13-2012, 12:18 PM
  2. Supercharger and TB porting
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2011, 07:57 PM
  3. Gen V Supercharger Porting
    By ls6velless454 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2010, 05:35 PM
  4. Supercharger Outler Porting
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:54 AM
  5. porting supercharger specs please
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 01:18 AM
