Thread: engine swap
Results 1 to 5 of 5
  1. #1 engine swap
    Dec 2013
    kentucky
    can anyone tell me if a 76 firebird 350 engine and trans will bolt up in a 79 grand prix that has 301 in it. any info would be appreciated!
  2. #2 Re: engine swap
    is the firebird engine is a pontiac engine or a chevy engine? if both are pontiac engines it should all bolt right up.
    350 is a chevy engine, pontiac never made one.
  3. #3 Re: engine swap
    just did some digging, they did have a 350 from 68 - 77. it may have been a olds engine tho. should bolt right up still. the bell housings on the tranny should be the same.
    and the motor mounts should line right up as well.
  4. #4 Re: engine swap
    Dec 2013
    kentucky
    it is a pontiac 350 out of 76 firebird. i have 79 grandprix with 301 in it.if the 350 engine and trans will bolt up to mounts and tranny mounts i would rather rebuild the 350 and put in as long as i dont need to do a bunch of modifications to switch. i think bell housings are different from 350 to 301 but i got trans out of firebird also
  5. #5 Re: engine swap
    the trans bell housings are the same, i put a th400 from my 70 formula 400 firebird into my 77 caddy with a 426 or some crap. my swap was a th400 to a th400, the only thing i had to do was swap the tail shafts so it would be the right length.
    my friend had a 77 gp. it had a 301 stock, we put a 326 in it, then a 400, then a 426, the same tranny was used every time.
    the only difference if you change the engine and tranny and the trannys are different, the 400 is longer then a 350 tranny, so the drive shaft will have to be dealt with. and the yolk on the end of the trans may have to be changed to match the drive shaft u joint size.
    and the trans cross member would have to be moved, but most cars back then had a few holes in the frame already to move the cross member so it lines up with the tranny mount.
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
