Thread: Do I have a thermostat issue on my 04 GTP?
Results 1 to 13 of 13
  1. #1 Do I have a thermostat issue on my 04 GTP?
    Sep 2012
    AZ
    Hey guys, I'm new to the Grand Prix world, always from a grand am GT.
    What I'm wondering is if my thermostat is going bad. In my grand am, within 5 minutes the car was fully warmed up with needle half way in middle.
    With the GTP, it takes forever for it to start moving. I drove 30 miles this morning in 29 degree weather and t never went past the first marking ( 1/4 of the gauge ) Then there's times it takes a while to heat up but will be what I think is normal and half way up, but at stops, she'll creep up past halfway just a tad.
    This seem normal for this car?
    Thanks!
  2. #2 Re: Do I have a thermostat issue on my 04 GTP?
    GTX Level Member HVACgtp's Avatar
    Oct 2012
    South Jersey
    It's normal to take a while for it too heat up, mine takes 10 mins maybe 15 of normal driving at 25 degree weather to heat up. And it will fluxuate a bit wen stopped, never really goes about half way
    2001 Silver GT; K&N Intake, 2.5in catback to flowmaster 40's, custom tune, led tails drag wheels and halos......SOLD
    2004 Silver GTP - its got some stuff http://www.grandprixforums.net/deja-vu-71112.html
  3. #3 Re: Do I have a thermostat issue on my 04 GTP?
    The key is..do you have a check engine light that results in a code saying not heating up fast enough?
    If no..smile and drive on.
  4. #4 Re: Do I have a thermostat issue on my 04 GTP?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Yup, and that would be a P0128.
    Just installed a new 195 in my 06 to fix this issue myself.
  5. #5 Re: Do I have a thermostat issue on my 04 GTP?
    Oct 2012
    South Jersey
    Didn't know there was a code for that, learn something new everyday
  6. #6 Re: Do I have a thermostat issue on my 04 GTP?
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    My '02 GT would get an SES light. Code indicated engine was not able to get to operating temp. Only happened in the winter. Changed the thermostat out, light went out, and we're all happy.
  7. #7 Re: Do I have a thermostat issue on my 04 GTP?
    Sep 2012
    AZ
    Okay, I won't stress too much then. I just found it weird 30 miles of 80mph and it didnt go past a quarter way up.
  8. #8 Re: Do I have a thermostat issue on my 04 GTP?
    I live here. TLSheff's Avatar
    If you haven't ever replaced it you may consider installing a new thermostat and flushing the coolant. Might help a bit, but probably not much.
    A its cold outside
    B your driving 30miles in cold weather
    Agreed tho, if no light is on, smile and let her stay cool, cool is good, if she's too cold, she will let you know.
  9. #9 Re: Do I have a thermostat issue on my 04 GTP?
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Question: Do you start the car and immediately crank the heat? The heater core acts as a second radiator. If you let the engine warm up a bit by driving, the heat will work better.
    You might also try driving in second gear for a while (stay below 40mph)
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  10. #10 Re: Do I have a thermostat issue on my 04 GTP?
    SWPA
    A "1/4 way up" is normal on an 04+. If you start getting to the second mark, the "middle" mark, then you need to worry about it getting TOO warm.
  11. #11 Re: Do I have a thermostat issue on my 04 GTP?
    Sep 2012
    Bangor, ME
    Stealthee: I posted a pic over in the "thermostats" thread. For a GP with a 195 stat and Ill post it up here too, the middle mark is not abnormally high. The middle mark is approximately 210-212. At idle, many GPs 04 and up go to the first line past the middle mark (221) before the fans kick on and bring it back down to 200.
    For someone with a 180 stat cruising range is between the first and second line past the quarter mark
    GOD BLESS...
  12. #12 Re: Do I have a thermostat issue on my 04 GTP?
    SWPA
    I've got a 195 and mine only ever hit the "middle" mark when I was low on coolant from a leaking water pump.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I was getting the same code and it WAS my thermostat, I bought a high flow 180 from Zzp and it works great..now that it's fixed I can definitely see an improvement in warm up time
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. Thermostat
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-04-2012, 11:30 AM
  2. Thermostat Cap
    By Points70 in forum General Tech Discussion
    Last Post: 04-30-2012, 05:24 PM
  3. 160 or 180 thermostat
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2012, 11:08 AM
  4. Thermostat
    By jaydasparkz in forum Engine
    Last Post: 12-10-2011, 10:49 PM
  5. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
