Thread: Key stuck in ignition what to do?
Results 1 to 6 of 6
  1. #1
    mi
    Once you start sticking stuff up your button, you're screwed.
    Sent from my SPH-D710 using Tapatalk 2
  2. #2 Re: Key stuck in ignition what to do?
    Omaha, NE
    Quote Originally Posted by raverockstar View Post
    I need to stick stuff there all the time.
    Quote Originally Posted by siLversLeigh View Post
    LUL!
    How to fix it:
    If you take the bottom cover off of the steering column you can get to it rather easy and remove the solenoid.
    1) tilt wheel all the way up and remove tilt wheel lever.... just pull, it comes out rather easy
    2) take out screws in bottom steering column cover.... torx bit
    3) pull off cover. you will have to tilt it a little to clear the rear clips.
    4) remove screw(s) holding in solenoid.... very small nut driver or pliers will do the trick.
    5) unplug wires to solenoid and discard solenoid into nearest trash can and save money for beer after job is complete
    6) reverse order to reassemble column
    7) use money saved from step 5 and go have a few beers
    This link has pics
    http://chrisb.users.superford.org/Gr..._Solenoid.html
  1. Ignition getting stuck again
    By vertebrate in forum General Tech Discussion
    Last Post: 08-30-2012, 09:34 PM
  2. Key gets stuck in the ignition
    By mikethevike384 in forum Introductions/Noob Questions
    Last Post: 04-15-2012, 11:33 AM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. key stuck in ignition
    By super steve in forum General Tech Discussion
    Last Post: 11-19-2011, 02:38 AM
  5. Key stuck in ignition.
    By at2smithjason in forum General Tech Discussion
    Last Post: 03-31-2010, 06:16 PM
