Thread: Ignition getting stuck again
Results 1 to 8 of 8
  1. #1 Ignition getting stuck again
    May 2008
    I was having a problem with my 2000 GTP where the key would come out in the ACC position and not turn to OFF. I replaced the ignition switch about a month ago, and that seemed to fix things. Yesterday it happened again though. The screwdriver in the column worked to get it to turn off, but obviously I want to get things fixed.
    Where should I look next? Should I look at the lock cylinder itself? I think I also read something before about it maybe being something to do with the shifter sensor not knowing the shifter is in park?
    Thanks,
    Steve
  2. #2 Re: Ignition getting stuck again
    park lock solenoid, in steering column.
  3. #3 Re: Ignition getting stuck again
    May 2008
    Is there any specific way to test that it is that, or just replace and see?
  4. #4 Re: Ignition getting stuck again
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    take the bottom part of the steering column off find the button on the park lock solenoid and wrap it in tape youll never have a problem with the key not coming out again
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  5. #5 Re: Ignition getting stuck again
    most just rip it out and never worry about it again.
    Indiana
    I had the dealer bypass mine and have had no issues. Car can be shut off while in gear now, but that's it.
  7. #7 Re: Ignition getting stuck again
    Ridin' the Blue IrishNation24's Avatar
    San Diego, CA
    yep, this is what i did. thats all you need to do man, no sense spending all kinds of money trying to fix it. ive had it this way for like 3 years, and i have never (as the dealer put it) accidentally turned it off while driving, or any of that nonsense.
    http://www.grandprixforums.net/membe...lbums-car.html
    2001 GTP special edition. lots of mods.
    1994 Greenwood C4 LT1-traded in for 6700 with 160K miles for....
    a 2004 LE MANS COMMEMORATIVE EDITION Z06 23K MILES.
  8. #8 Re: Ignition getting stuck again
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    x2, easy fix, $0 cost
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  1. Key stuck in ignition
    By tigers40 in forum General Tech Discussion
    Last Post: 07-01-2012, 05:22 PM
  2. Key gets stuck in the ignition
    By mikethevike384 in forum Introductions/Noob Questions
    Last Post: 04-15-2012, 11:33 AM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. Key stuck in the ignition
    By Gearhead Garland in forum General Tech Discussion
    Last Post: 01-31-2012, 06:32 PM
  5. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
