Thread: Door Lock Problem
Results 1 to 4 of 4
  1. #1 Door Lock Problem
    SE Level Member Lowdown112's Avatar
    Dec 2012
    Louisville
    My passenger side door lock wont lock at all. Not by the lock button or manually locking. Its very stiff when I try to lock it manually, and when it does move it goes right back into unlocked position. I dont know much about locks or even this car just bought it a few days ago. But I want to get it fixed before I start modding it. Last thing I need is it get stolen, and I live in the city. Please help, its 99 Grand Prix 4 door GTP if that matters.
  2. #2 Re: Door Lock Problem
    St. Louis
    Sounds like the lock rod may be bent out of shape and binding up on something inside the door. Pull the panel and see what it might be hitting.
  3. #3 Re: Door Lock Problem
    trenton, on
    Quote Originally Posted by Lowdown112 View Post
    had the same problem with mine. ended up being the door lock solenoid. be warned, anything to do with inside the door is going to be a serious pita!! make darn sure you know where all the rods go to before disassembly. take pics if you have to. good luck!!
  4. #4 Re: Door Lock Problem
    Dec 2012
    Louisville
    Quote Originally Posted by johnpstuart View Post
    I know I rigged it enough to where I can get it open and closing. It still wont lock but im through messin with it. I usually fix everything on my own but this is a pita. Ill just have someone do it professionally..:P
  1. 2008 Grand Prix Door Lock Problem
    By SMac68 in forum General Tech Discussion
    Last Post: 11-21-2017, 10:59 PM
  2. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  3. interior light/door lock/alarm problem
    By nicknitro in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2011, 05:03 PM
  4. Auto Door Lock Problem-2000 GTP
    By sandjaso in forum General Tech Discussion
    Last Post: 08-31-2009, 07:25 PM
  5. Power Door Lock Problem-O
    By flynn in forum General Tech Discussion
    Last Post: 12-31-2007, 04:49 PM
