Thread: Aftermarket stereo harness
Results 1 to 9 of 9
  1. #1 Aftermarket stereo harness
    Jul 2012
    Bloomington, IL
    2005 GP GTP
    I'm looking at putting in an aftermarket stereo for the first time, and I was told by BestBuy that I needed the $105 GMOS-04 wire harness because the factory harness to the radio controls other things like the Airbag, etc. I just have the original stock stereo, and I do not have the Onstar controls. Has anyone else ran into this? Or have first hand knowledge of installing an aftermarket stereo in the 2005?
  2. #2 Re: Aftermarket stereo harness
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    GMOS-04 will allow you to keep you RAP functionality, and your Door Chimes. It also has the harness integrated to easily add Steering Wheel Controls (Still requires the ASWC Module as well though).
    If you don't care about those things and want to cheap out, you can run the 70-2003 harness. This isn't totally plug and play though, because you need to find a switched power source someplace (I typically go direct to the ACC wire in the ignition harness.)
    Either harness shouldn't have an effect on your airbag functionality.
    My recommendation is to do it right, buy the GMOS-04.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  3. #3 Re: Aftermarket stereo harness
    If you purchase it with a stereo from Crutchfield its only $49.99.
  4. #4 Re: Aftermarket stereo harness
    Jul 2012
    Bloomington, IL
    So if I go with the GMOS-04, and the SWI-JACK (For steering wheel controls), then I should be good to go?
  5. #5 Re: Aftermarket stereo harness
    Oct 2012
    Pinckney, MI
    You'll also need a 40-GM10 Antenna adapter, and a Dash Kit (Not sure the number on that one.)
    -Rob
  6. #6 Re: Aftermarket stereo harness
    Jul 2012
    Bloomington, IL
    Yes. I'll have the Dash Kit and Antenna adapter as well.
    One last question... The Metra ASWC or the PAC SWI-Jack? Is one easier and/or better than the other?
    Oh...And are there different GMOS-04 harnesses? I see some that say Onstar, and some that say amplified. So are all GMOS-04 harnesses the same?
    Oct 2012
    Pinckney, MI
    There's a couple of generations, make sure the one you get is the latest.
    Go Metra for the ASWC. It'll plug right into the gmos, and you just have to cut 2 or 3 wires (follow the manual!)
    -Rob
  8. #8 Re: Aftermarket stereo harness
    Jul 2012
    Bloomington, IL
    Ok. I lied. One more question. If I don't have the Monsoon system, is the GMOS-04 still required? I believe I only have the Base Model according to the owners manual.
    Oct 2012
    Pinckney, MI
    If you don't have the monsoon system (no speaker in the center of the dash) you need the GMOS-01 instead of an 04.
    -Rob
  1. Aftermarket stereo HELP!
    By IAMABANANA MOOO in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2012, 11:47 AM
  2. Special wiring harness for aftermarket stereo for newer gp
    By MattTheBaker123 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2012, 12:28 AM
  3. Aftermarket Stereo Problems?
    By RedFace in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2011, 01:23 AM
  4. wiring harness aftermarket stereo
    By LeThAlREMiX in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2011, 12:41 AM
  5. Aftermarket stereo in 06 GP with Monsoon
    By GXP Bill in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2009, 01:23 PM
