Thread: Wierd idle
Results 1 to 9 of 9
  1. #1 Wierd idle
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    My cars idle has been really wierd lately. It will be idling regularly for a minute and then it will start reving up and then acting like its gonna cut off and then itll cut off after doing that for a minute. Any ideas what it could be?
  2. #2 Re: Wierd idle
    SE Level Member Bessesen2's Avatar
    Jul 2012
    Livonia,MI
    Most likely a cat. Same thing happened to my 1998 GT. took off the cat and it worked fine after that
    1999 Grand Prix GTP. 157xxx miles and climbing everyday.
  3. #3 Re: Wierd idle
    Apr 2012
    Myrtle Beach, SC
    Well my check engine light is on now and it is the code p0102.
  4. #4 Re: Wierd idle
    Jul 2012
    Livonia,MI
    You will have to look up the code online
  5. #5 Re: Wierd idle
    Jul 2012
    Livonia,MI
    It is the mass air flow sensor code.
  6. #6 Re: Wierd idle
    Well...then ya know what is causing the issue.
    What's cutting off, how do you do that..does it require scissors? lol Sorry...had to.
  7. #7 Re: Wierd idle
    Apr 2012
    Myrtle Beach, SC
    But where should I get one because I heard someone say that the autozone ones are crap.
  8. #8 Re: Wierd idle
    St. Louis
    Junkyard, Morad, someone on here... JY will probably run you about $40 or so. Just match the number that is on the top of your MAF to the one in the yard. They have to match. And no, it doesn't have to be from a GP. Can be any 3800 as long as the #'s match.
    You could try cleaning the MAF and see if that fixes it. Worth a shot. Remove it, spray it down w/ MAF cleaner (not carb or brake cleaner) and dry. Reinstall and see what you get.
  9. #9 Re: Wierd idle
    I live here. TLSheff's Avatar
    I have one installed from Oreillys. I think it came with a lifetime replacement warranty too, but it was kinda pricey. Fixed my problem.
    One thing, have you removed the screen from the throttle body, sometimes this can cause turbulence and a rough idle and occasionally throw a code.
    Otherwise. this is what Google says.
    P0102 OBD-II Trouble Code
    Technical Description
    Mass Air Flow (MAF) Circuit Low Input
    What does that mean?
    Basically this means that there is a problem with the Mass Air Flow (MAF) sensor or circuit. A more technical description would be that the MAF circuit had lower than expected voltage (air flow). Other MAF sensor circuit DTC trouble codes are P0100, P0101, P0103, and P0104.
    Symptoms
    You will likely not notice any serious drivability problems, although there may be symptoms such as a general decrease in power or sluggishness.
    Causes
    A code P0102 may mean that one or more of the following has happened:
    • The MAF may be disconnected, or a wiring connection may be bad
    • The MAF may be dirty or otherwise contaminated (Note: if you use a reusable oiled air filter, be careful not to apply too much oil or that can contaminate the MAF).
    • The MAF sensor may be faulty
    • The vehicle computer may be faulty (very rare)
    Possible Solutions
    The simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures:
    • Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires.
    • Inspect for any air leaks near the MAF sensor.
    • Take the MAF out and clean it using a spray cleaner such as brake cleaner or electrical contact cleaner. Be gentle with the sensor.
    • Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information)
    • Replace the MAF sensor.
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. Wierd Sound
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 02:22 PM
  4. Alt. Died. I replaced, Now my idle is wierd.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 09:22 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
