Last night when going to work i noticed my battery indicator light on. I was told by a fellow member to test the ALTERNATOR and go from there. I drove 30 miles to the nearest Advanced had it tested. Car showed 10volts and sure enuff it was bad.
Ok.... Figured as much anyways. I bought a new one. $182.00
On the way back home. ABS light and TCC comes on. Ok... this is weird.
SO 10 miles later the lights and power start fluctuating and it's holding in 3rd. It's not going to OD either. But as long as i keep my foot at a consistant 3k it will stay running.
5 more miles, i loose all electrical. I decide to try to make it 15 more miles to my residence. I get into town start to slow down and it dies for good. I cost a mile and let her rest.
Get tools, get a charger and change the alt in the County fairgrounds lot.
Start her up and the idle sounds like I have a cam.
I just replaced the MAF last week. I unplug it and it idles smoothly but at 1500k and will not "Kick down" to it's normal idle. I get home put it on the charger for the rest of the day until the wife gets home. It has a full charge and showing 12.5 volts.
I start her up tonight to go to work and the idle is still funky. I unplug the maf again and the idle smooths out. Then i plug the MAF back in while running and its still idling smooth but at a higher RPM around 1500k.
I put it into Neutral at a stop light while waiting and it goes above 2000k on the tach. Put it back in drive down to 1400k. I drive it to work and shut it off then start it back up.
Idle sounds like i have a Cam again but lower around 800 to 1000k.
I am stumped. Did the power fluctuation when i was driving it Screw some sensor up? Did i miss something ? Everything is plugged in. I've looked at the vac lines. I can re-examine them though.
One member said it could be a bad ground causing Hell
Please help me out guys i'm in great need.
Thanks in advance.
-Ryan
