Thread: 08 turn-signal & brake light issue
Results 1 to 2 of 2
  1. #1 08 turn-signal & brake light issue
    Oct 2012
    Appears the light in the front passenger side turn-signal shorted out. The bulb blew, put in a new one & no difference. Can't find a wiring diagram for this, but that bulb connection seems to direct not only the front turn-signal, but also the back on the same side & the brake light on that side. Dash indicator hyper flashes when it's tuned on; running light blinks on front, but not the signal itself, front or rear & just found out by being pulled over that the brake light on that side isn't working now either. Put new bulbs in all locations, front & rear - no change. The inside of the bulb connection for the burnt light in front looks burnt itself, but the metal connection in it is not corroded at all. Could this be the wiring harness that runs from the low-beam, high-beam & the turn signal to the main harness? Have also checked all fuses & all are okay.
    Please advise, before I buy something I don't have to & still don't fix the danged thing!
    Thanks!
    Dee
  2. #2 Re: 08 turn-signal & brake light issue
    St. Louis
    Check for power at the bulb connection. If it burnt then it may not be getting enough (or any) voltage.
  1. Turn signal and wiper issue...read on!
    By juggalette79 in forum General Tech Discussion
    Last Post: 04-24-2012, 09:42 PM
  2. turn signal issue please help if you can.
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 12-08-2011, 09:36 PM
  3. 05 GTP Turn signal issue
    By ubmarine in forum Audio, Security & Visual Electronics
    Last Post: 05-03-2011, 07:45 PM
  4. 2005 GT Turn signal issue.
    By Mac2005GT in forum General Tech Discussion
    Last Post: 04-07-2011, 10:29 PM
  5. Brake light, turn signal, cigarette lighter wont work
    By dlouis30 in forum Introductions/Noob Questions
    Last Post: 03-02-2010, 10:07 PM
