Thread: boost only when cold
Results 1 to 20 of 21
  1. #1 boost only when cold
    Destroys cars izup69's Avatar
    Iowa
    Ok so I have had this problem for a while now the car only gives me full boost while It is cold. Once the car warms up it no longer gives me boost. Im just about ready to have the computer relearn factory settings. I have not messed with the pcm the previous owner did.
    Car dont shift when it is suposed to and other stuff has lead me to beleave this. Just take a look at these logs and see if you can tell anything outa whack. If you need more info just let me know and ill log more data points. These where taken with torq I have highlighted the areas where I run into boost.
    Download data log.csv for free on uploading.com I think that link works. But I'm at work so it wont work for me. Thanks for all the help
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: boost only when cold
    I'm guessing this is on the '97 GTP?
    Have you checked for vacuum leaks?
    Any SES lights?
    BBV moving correctly?
  3. #3 Re: boost only when cold
    Iowa
    I have checked everything possible. no vac leaks bbv works fine it opens all they way up when I hammer on it. no ses lights the car is in perfect shape except for this one problem.
  4. #4 Re: boost only when cold
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    I have a thought, maybe the car isnt getting enough air or maybe its just not dense enough. Check ya exhaust back pressure too, that should be no higher than 1 1/2-2psi at WOT or at least 4k-5krpm. Maybe your not getting enough air in and enough air out. That air flow restriction could disrupt the boost psi.
    It works in the morning while the engine is cold but dosent work correcty once at operating temp. Possibly the air flow at diff temps or your car may only be operating off of open loop correctly(cold start until engine reaches operating temp) and once in closed loop(operating temp), something may be off affecting the boost
    Hope this helps, Dee!!!
  5. #5 Re: boost only when cold
    Iowa
    I have open cone k&n and a full magniflow exhaust. I dont think it is the air in/out. But I will check. What is the best way to check? Im guessing its something to do with open/closed loop. I never had this problem when I got the car. But it was in the fall and air temps were cooler. And this problem only started when it got hot out. So with that in mind might be the air is not dense enough and the car has something changed in the computer that kills boost when its in closed loop.
    Would a computer re-learn fix this problem ?
    I have a spair 97 computer but I think it is fried. When I hook it up to the car it wont even start. So I might just get that one re-programed and see if I can use it since this car is my dd at the moment. And I don't have the time to put it in the shop.
  6. #6 Re: boost only when cold
    GT Level Member BrendanMurphy's Avatar
    Jan 2012
    Keswick, Ontario
    Im thinking it's maybe the cat clogged up. It can only create problems sometimes when the car is warmed up.
  7. #7 Re: boost only when cold
    Iowa
    See I think it has the orig cat on it. Not positive tho. I'm half tempted to cut a hole in front of the cat and see if that makes a diffrence then I can just weld the hole shut with some spair steel if that is not the problem. It has ben sugested that it was the problem. But it sure dont seem like its cloged.
  8. #8 Re: boost only when cold
    Jan 2012
    Keswick, Ontario
    Quote Originally Posted by izup69 View Post
    Let the cat idle and warm up try it from cold as well. But rev it and see if it hesitates, i believe the rev limiter on gtps is 4000? But if it hesitates at all its time to cut a whole in it or take it out
  9. #9 Re: boost only when cold
    Jul 2012
    North Philly
    Yup, the cat being part of the way ya car breathes could definately be causing some air flow issues. In the case of that not being the issue, trying to let the PCM re-learn itself may work. if not for this issue, it may very well fix another or prevent one from happening.
    To do a back pressure test, just put a PSI guage into the O2 sensor location. S1(upstream O2 sensor) port will tell u the psi b4 the cat and S2(downstream O2 sensor) will basically tell u the PSI after the cat(for the mufflers and pretty much the rest of the system). So use S1 port to check the CAT
    Shouldnt be no more than 2psi at WOT and really not even that much, should be a lil less than 2psi especially with u having it modded a lil(should be breathing pretty good unless it is clogged somewhere)
    Let us know............
  10. #10 Re: boost only when cold
    That. ^^
    Should be 0-1 psi of back pressure.
    Hell just take the upper o2 out and drive it around the block, it'll sound like a tractor, but if you dont have a pressure gauge, its another way of doing it.
  11. #11 Re: boost only when cold
    Iowa
    Yeh Ill try that guys. I have some time off at work comeing up here so I should be able to get to it this weekend. If it is the cat I got some spair exhaust pipe laying around I will just delete the dam thing. Thanks for all the input. I might even be able to get to it today after work. Will have to see what the wife wants me to do around the house :/
  12. #12 Re: boost only when cold
    Iowa
    Ok so I tryed to work on my car over the weekend. Didnt work out to well but I did manage to find a exhaust leak I was looking for. It is right after the cat. I do Not a s1 o2 port only s2 If i have a s1 I cannot find/see it on my dp to remove it. Didnt have the time to drill a hole in my dp and then re-weld it (it started to rain and as most of us know water plus high voltage don't mix) I don't have the cash yet to have the pcm re-learn at the garage. So for now I will just have to live with the problem. (saves me money on new tires)
  13. #13 Re: boost only when cold
    the bank one o2 sensor is right beind plug number 6, its in the rear manifold.
  14. #14 Re: boost only when cold
    GT Level Member thegipper's Avatar
    grafton, wi
    What he said.
    Unscrew it and temporarily fasten it somewhere. Drive it around. If it drives better then you know you have a clogged cat.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  15. #15 Re: boost only when cold
    Iowa
    sorry couldnt see it. Ill rip it out tonight if the rain stops. If it is my cat will be a good time to fix the masive exhaust leak that makes the car sound like a pos. EDIT: I tryed getting it off but to no avail. Absolutly not enuf room to turn a wrench in there. Hopefully I can make it to my parents house this weekend and ill just cut the dam cat out once and for all.
  16. #16 Re: boost only when cold
    Jul 2012
    North Philly
    So wus the verdict??? Any luck.....
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  17. #17 Re: boost only when cold
    Jul 2012
    North Philly
    U definately have a upstream o2 sensor, if u didnt your car would run so ****ty
  18. #18 Re: boost only when cold
    Probably KR.
  19. #19 Re: boost only when cold
    Ontario
    Probably KR.
    Knock sensors only engage around 160 correct?
    GT Level Member Utter99's Avatar
    Warsaw indiana
    ^ yes but it'll pull timing instead
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  1. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. hello from cold ny
    By ASCStinger in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 12:33 PM
