Thread: What does this connector go to?
Results 1 to 8 of 8
  1. #1 What does this connector go to?
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Found this in the back of the engine bay near the alternator. Car is a 2000 Grand Prix GT. Anyone know what this goes to?
  2. #2 Re: What does this connector go to?
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    I have an 02' GT Coupe and have the same connector loose as well. I'll be curious as to what it is as well. I can't see it going to anywhere on the motor.
    2002 GT Red, Stock, Work In Progress..........
  3. #3 Re: What does this connector go to?
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I have that plug also, I was told its emissions related That non California cars didn't use.
  4. #4 Re: What does this connector go to?
    Dec 2011
    Michigan
    Quote Originally Posted by chicagochuck View Post
    Yeah there's nothing for it to plug into so you're probably right.
  5. #5 Re: What does this connector go to?
    Maybe used a cali car or it could be something for a GTP motor and is just left unused on your GT engine.
  6. #6 Re: What does this connector go to?
    Aug 2012
    Port Chester, NY
    Well thats good to know. Thanks!
  7. #7 Re: What does this connector go to?
    Mar 2012
    NC
    I have it on my 97 GT...it's like an additional purge valve or something. Regardless, it goes to EVAP and if you don't have it then no worries.
  8. #8 Re: What does this connector go to?
    Pennsylvania, USA
    If it stops raining here I'll check to see if my 05 has it plugged in, I've got the stupid secondary air pump for CA. Makes taking off the rear valve cover kind of irritating, can't wait to tune the code out so I can delete the system :/
  1. what's this connector?
    By 3100sfi in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-03-2011, 07:12 AM
  2. what and where does this connector go?
    By fst in forum General Tech Discussion
    Last Post: 07-13-2011, 03:45 PM
  3. Where does this connector go?
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2008, 09:34 AM
  4. Where does this connector go?
    By alacran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2008, 07:19 PM
