Thread: large coolant leak???
Results 1 to 12 of 12
  1. #1 large coolant leak???
    SE Level Member jakedidi's Avatar
    minnesota
    so i parked at about a 20* incline and went to go eat. came back out and there was coolant all over tthe ground. was coming from the back of the engine. below the exhaust manifolds. coolant elbows and all hoses are fine. when i got it home and on a flat surface it didnt leak. filled it up and it still didnt leak. ran it and it didnt leak. anyone have any ideas?
    i did recently switch from dexcool to green. flushed the entire sytem and bled it. was not beating on it. just normal driving...
    trying to figure out what it is before i tear into it.
  2. #2 Re: large coolant leak???
    if the leak was dead center of the engine and behind it check the heater core hoses where they clamp on to the core tubes at the fire wall.
    i had a hose end go bad and it leaked down the fire wall padding and hit the ground. the padding will get wet and damp feeling under the hoses if this is leaking, or if you see it leaking from the firewall at the bottom
  3. #3 Re: large coolant leak???
    minnesota
    that was the first thing i checked. and thats why i said the hoses were fine.
  4. #4 Re: large coolant leak???
    my hoses "looked" fine too. once they got hot it leaked.
    if your not finding any wet trails from the pulley side, and its dripping in between the engine and tranny, the only thing there is the freeze out plugs, one may be rusted up and leaking.
    and to change them you need to drop the trans or pull the engine to fix them on that side.
  5. #5 Re: large coolant leak???
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    how much fluid was in your coolant bottle the overflow outlet is on the back of them that can leeak at the right level of coolant and angle of car
  6. #6 Re: large coolant leak???
    minnesota
    Quote Originally Posted by Erik Adam Rodriguez View Post
    definately not the overflow... as i said back of the engine. hoses are fine. ill check the freeze plugs
  7. #7 Re: large coolant leak???
    Kansas
    Clean any coolant spots you see. Get the car to normal running temperature and check around. Doubt its a freeze plug, but who knows. Possibly a bad UIM/LIM gasket, and being on an incline made the coolant pool up in the LIM and pour out the back. Along with the UIM gasket could be intake manifold is warped if it's never been replaced. (i.e. not the newly reinforced plastic)
  8. #8 Re: large coolant leak???
    do you know how much coolant would have to be in the lim bolt valleys to spill out over the valve cover (never gonna happen) or even down to the sides of the engine.
    i have a bunch of leaking bolts as we speak, and nothing makes it to the ground, not even the end bolt that looks like its crying when the cars good and warmed up.....
  9. #9 Re: large coolant leak???
    Kansas
    I'm not saying it's an everyday occurrence, but could happen... cause after all it is a GP.
  10. #10 Re: large coolant leak???
    May 2016
    PA
    And...
    for 4 years
    no one knows the end of the story
  11. #11 Re: large coolant leak???
    GT Level Member mainecrab's Avatar
    Feb 2008
    I agree with the hoses. My car leaked from there and it wasn't apparent. I would lose coolant and would hear the swishing sound of water going through the heater core. Changed the hoses as they were old and bloated anyways and never saw an issue again. If they are old or never been changed do that first.
  12. #12 Re: large coolant leak???
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. Large Exhaust leak, Most likely place?
    By benner in forum General Tech Discussion
    Last Post: 02-11-2011, 01:43 PM
  3. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  4. Large EVAP LEAK and FUEL CAP LEAKING?????
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 12:55 PM
  5. HELP! FP leak at large quick disconnect!?!
    By alacran in forum General Tech Discussion
    Last Post: 07-24-2008, 01:01 PM
