You'd think this would be common enough to search for "wet passenger footwell" or "body drain", but coming up empty on both counts.
It rained, and I have a lot of water in the passenger footwell. I'm guessing that the body drain is clogged. Usually cars have a small opening in the rocker panel seam that acts to drain water, and which usually gets clogged. Does that drain exit at the seam, or do I need to remove something to get to it?
thanks.
Sean
