Thread: Rain leaking into passenger footwel- wher's the drain exit?l
Results 1 to 4 of 4
  1. #1 Rain leaking into passenger footwel- wher's the drain exit?l
    Aug 2008
    Hamilton, OH
    You'd think this would be common enough to search for "wet passenger footwell" or "body drain", but coming up empty on both counts.
    It rained, and I have a lot of water in the passenger footwell. I'm guessing that the body drain is clogged. Usually cars have a small opening in the rocker panel seam that acts to drain water, and which usually gets clogged. Does that drain exit at the seam, or do I need to remove something to get to it?
    thanks.
    Sean
  2. #2 Re: Rain leaking into passenger footwel- wher's the drain exit?l
  3. #3 Re: Rain leaking into passenger footwel- wher's the drain exit?l
    Aug 2008
    Hamilton, OH
    Thanks! I'll order the part Tuesday and hopefully be done with this.
  4. #4 Re: Rain leaking into passenger footwel- wher's the drain exit?l
    GT Level Member glendayle's Avatar
    Salt Lake City
    Not really an easy way to hit the floor pan plug. Just get as much water out as you can and put a fan on it, or door open in sunlight, or whatever.
    You can see where the plug is in this pic.
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  1. A/C Leaking into passenger compartment?
    By Korben in forum General Tech Discussion
    Last Post: 06-23-2012, 06:45 AM
  2. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  3. rain water on passenger floor
    By talontedGTP in forum General Tech Discussion
    Last Post: 06-11-2011, 11:32 PM
  4. Leaking in heavy rain - from sunroof???
    By kevin79 in forum General Tech Discussion
    Last Post: 05-29-2011, 05:01 PM
  5. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
