Thread: Engine problems.......
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
  1. #1 Engine problems.......
    strathmore alberta
    Have a 06 base model .......put a HP tune on it.......took all restrictions off but at 200 km/h engine shuts off and all communication ti computer stops...is there a safety on the car that is hard wired in it ..or am I missing something to turn off....no codes come up either
  2. #2 Re: Engine problems.......
    why do you need to go that fast?
  3. #3 Re: Engine problems.......
    Because the road is straight for hundreds of miles.
    strathmore alberta
    The car won't get the proper tune as the dyno won't give a true torque reading as the engine shuts down
    Right now had to set at 180 for torque at 160 wheel horse power
  5. #5 Re: Engine problems.......
    Quote Originally Posted by draftrcn View Post
    does that even mean?
  6. #6 Re: Engine problems.......
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Sounds about right to me.
    GPONA #1 Cyber Bully
  7. #7 Re: Engine problems.......
    I dont understand your logic of tuning.
    What does knowing the "true" torque numbers going to do?
  8. #8 Re: Engine problems.......
    strathmore alberta
    Better performance....
  9. #9 Re: Engine problems.......
    What
  10. #10 Re: Engine problems.......
    Car makes no power, takes 10's of seconds to reach those speeds. Kind of a waste of time and money really.
  11. #11 Re: Engine problems.......
    strathmore alberta
    Was a simple question .....what I do with my car is my choice just asked if there was a secondary safety
  12. #12 Re: Engine problems.......
    So HP tune as in HP tuners was used? What are you tuning with?
    Knowing what the motor makes for torque means nothing.
  13. #13 Re: Engine problems.......
    strathmore alberta
    And not a waste of time I increased my fuel economy by 20% and got more power
  14. #14 Re: Engine problems.......
    strathmore alberta
    Ya HP tuner ...and was put on a actual dyno and ran through its paces
  15. #15 Re: Engine problems.......
    strathmore alberta
    My numbers are all wheel numbers not engine.....but like I commented on the dyno once my car hit 200 it completely shut down no codes
  16. #16 Re: Engine problems.......
    Cambridge, Ontario Canada
    Wish I had these 15.4 seconds of my life back... the car shutdown at 200 because GP's start to fly at 201
    2005 E55 - stock
  17. #17 Re: Engine problems.......
    strathmore alberta
    I have done all the work to make the car handle and stick to the road ....the flying is not a issue......
  18. #18 Re: Engine problems.......
    So I take you've adjusted airflow and fueling and messed with timing tables to gain power and fuel economy. But now you are at the mercy of the car and what it can do, you dont need to go that fast.
    Your NA is very limited with the power it can make and you might sneek out 200+ WHP with all the bigger mods such as cam, hv3 and so on. Its only going to be useful from 0-90 mph anything above that and it takes forever to reach such speeds.
  19. #19 Re: Engine problems.......
    20% fuel economy?
    Give me a break.
    You'll never get that just from a tune unless you put larger injectors in and don't adjust the tune for it.
    If the person who tuned your car was paying attention, they'd see there are speed cutoffs in multiple places.
    Takes but a minute to find them.
    Much less than the time you spent in this thread.
  20. #20 Re: Engine problems.......
    Doubt you got a pilots license - you need training before it's not an issue
    2005 E55 - stock
  1. Engine problems
    By mattstansbury in forum General Tech Discussion
    Last Post: 10-07-2011, 05:33 PM
  2. engine code problems
    By yeacashgpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2011, 06:08 AM
  3. Engine problems
    By kenizzle36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2011, 09:57 AM
  4. 2004 Engine Problems - help!
    By davepond88 in forum Introductions/Noob Questions
    Last Post: 07-23-2010, 04:34 PM
  5. Engine swap done, problems
    By atruebudfan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2009, 01:48 AM
