Thread: 04 GP Temp gauge gets 1 notch over the middle? also loss of acceleration?
Results 1 to 20 of 24
  1. #1 Re: 04 GP Temp gauge gets 1 notch over the middle? also loss of acceleration?
    If you have the stock pcm fan programming. Your fans don't come on until around 216F low speed and 228F for high speed. so unless you are moving, expect temps to rise. The transmission cooler is in the radiator... keep that in mind.
    FWIW I did two 8 hour runs in 90-95 degree heat the past week, through the hills of PA and they have some hills. The first leg was actually 85-90F outside and the trans averaged 190F with a 195F t stat. On the way back temps outside were 90-95F and the trans averaged 200F with one spike to 215F. 160F is considered the bottom of the operating temps for the trans. The high end is up around 230F.
    Ooooo lookey what I found
    Trasmision Automatic A Buick-Oldmobile 4T65E
  2. #2 Re: 04 GP Temp gauge gets 1 notch over the middle? also loss of acceleration?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I bought the day pass to download that. It looks to be a wealth of knowledge
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  3. #3 Re: 04 GP Temp gauge gets 1 notch over the middle? also loss of acceleration?
    Only temp stated is HOT which is 266* F.
    the thermostatic element should close, but the question is: at what temp does it close?
  1. Please help! Loss of acceleration.
    By Jeff Strange in forum Introductions/Noob Questions
    Last Post: 06-04-2012, 07:05 AM
  2. Temp gauge?
    By 2004GrandPrixGT1 in forum General Tech Discussion
    Last Post: 04-19-2012, 09:41 PM
  3. No power on acceleration when up to temp.
    By ABeam in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-21-2011, 05:32 PM
