FWIW, I pulled that wire at the module etc to wire up the mirror turn signals. Mirrors work 100%, which leads my issue to the headlight.
Another cool thing. When I did the LED bulbs..I found out that we have a goofy bulb up there. It's not a standard bulb. You can use a standard bulb most of the time, but LED standard will blow the fuse. Might be what's causing your issue is you need tor turn your bulb over.
