Thread: Are 04+ Cooling Systems Hard to Bleed?
Results 1 to 9 of 9
  1. #1 Are 04+ Cooling Systems Hard to Bleed?
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Greetings.
    I had my water pump replaced (by a shop) on Friday, since then I have driven 175 miles. I can still hear a little gurgling. The temperature stays within normal range, and I do not appear to be losing any coolant. Is this normal this many miles down the road? Or are these cars just a pain in the butt to bleed?
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  2. #2 Re: Are 04+ Colling Systems Hard to Bleed?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Pro Tip.
    1. Park on level ground.
    2. Remove bleeder screw.
    3. Place large funnel into radiator fill neck.
    4. Fill that ***** up until coolant comes out the bleeder.
    5. Profit.
    GPONA #1 Cyber Bully
  3. #3 Re: Are 04+ Colling Systems Hard to Bleed?
    Or, just fill the LIM with coolant, then the rad and bleed the cooling system and add as needed.
  4. #4 Re: Are 04+ Colling Systems Hard to Bleed?
    I'm with FFDP. A LIM air bubble will not always bleed out by radiator filling alone. I've come across a couple pissers that wanted the T stat housing and thermostat removed to fill at LIM.
  5. #5 Re: Are 04+ Colling Systems Hard to Bleed?
    Slower, Lower Delaware
    How do you know you have a LIM air bubble?
  6. #6 Re: Are 04+ Colling Systems Hard to Bleed?
    Pennsylvania
    Only time I encountered gurgling was a pinhole in the coolant elbow.
  7. #7 Re: Are 04+ Colling Systems Hard to Bleed?
    sounds like air caught up in the heater core, if you hear it from inside the car, from the center dash area.
  8. #8 Re: Are 04+ Colling Systems Hard to Bleed?
    Sep 2012
    Bangor, ME
    Thats about where its coming from. Should i run the heat on full for a while? Will this work itself out?
    GOD BLESS...
  9. #9 Re: Are 04+ Cooling Systems Hard to Bleed?
    the best way really it to remove both heater core hoses off the alt bracket, run a garden hose into one hose and flush the core out. if it burps when filling it with the hose you know you got it. fill it so both hoses are full of water and put them back on the car, then re bleed the t stat housing for the fun of it, you know to just make sure.
    i like to let my car idle, a/c off till the fans come on, i leave the rad cap off the whole time, topping it off as needed while waiting for the fans to kick on, once the fans turn on, then i bleed it. top it off if need be, cap it/done.
  1. how do i bleed air out of coolant system?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-08-2011, 01:21 AM
  2. Cooling systems, and Temp. : Meth Injection and Stat
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 02-20-2011, 04:50 PM
  3. How long to bleed the coolant.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 01-16-2011, 09:40 PM
  4. How do you bleed the master cylinder?
    By corsagtp in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2010, 05:30 PM
  5. Help quick! Coolant bleed?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2009, 08:14 PM
