Thread: DIC (Driver Info Center) Back lighting dim on one side?
Results 1 to 4 of 4
  1. #1 DIC (Driver Info Center) Back lighting dim on one side?
    May 2012
    Surrey, British Columbia, Canada
    When we bought the GTP a few weeks ago, I noticed that sometimes the DIC would get dim on the boost gauge side of it. A quick tap on top of the dash solved the problem for a while, but recently it has almost completely quit working. I assume a bad connection someplace, or a bad bulb. That is if the DIC even uses bulbs? Can anyone shed some light on this, (pun intended) It would really brighten my day, My face kinda lights up, when I see the boost gauge pegged. Ok enough with the bad puns.
    Seriously though, I would like to fix it, and don't know even how to open it up to get at it.
    Thanks in Advance.
    New GTP Owner. Totally Stock. Yes I am keeping the motor in the GTP, No I am not stealing it for one of my Fiero's. Car Details; 2000 GTP 3800 S/C Auto. Bose Audio. There have been Zero mods done to the car, so starting from a clean slate.
  2. #2 Re: DIC (Driver Info Center) Back lighting dim on one side?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    I thought I read a how to fix it somewhere. Maybe clubgp? There are two lightbulbs in there. Google it
  3. #3 Re: DIC (Driver Info Center) Back lighting dim on one side?
    Never Never Land
    The bulbs are replaceable. Same bulb type used in the gauge cluster. It's been too long since i've had mine apart though so I can't tell you how to get it apart to replace the bulb.
  4. #4 Re: DIC (Driver Info Center) Back lighting dim on one side?
    May 2012
    Thank You guys for the info. At least I know it is just standard Bulbs. I assume I just pry the panel around the DIC forward to gain access. That will be my mid week evening project.
    Then on to the front brakes, rear trailing arm and finally that damn fuel filter. (shop could not , would not remove it, as they said it was seized on so hard that they were risking damaging the fuel line.
    I think the car is leaning out in the high rpms due to it. So I have to get that done quickly.
  1. back lighting
    By dlk in forum General Grand Prix Discussion
    Last Post: 01-29-2012, 07:41 PM
  2. need lighting info asap
    By onetyme77 in forum Visual/Body Modifications
    Last Post: 11-29-2010, 03:30 PM
  3. back driver side speeaker
    By rmil03 in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2010, 08:47 PM
  4. Driver side wiper arm slips down to the side mirror
    By kappian in forum General Tech Discussion
    Last Post: 04-05-2010, 08:43 PM
  5. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
