Thread: Ignition
Results 1 to 12 of 12
  1. #1 Ignition
    GT Level Member gunsn88's Avatar
    May 2011
    Vineland, New Jersey, United States
    hey, okay this is the 3rd time my ignition switch just shut down my whole car for 4 hours, no power no nothing. and i can take my key out while its in drive, so is the issue the whole harness fir the switch? and now there the security signal blinking in my dash. i don't know how to turn it off. any help?
    Imagination is more important then knowledge.
  2. #2 Re: Ignition
    GTX Level Member blackflag's Avatar
    Virginia
    The ignition switch is attached to a harness. Buy it. Problem solved
  3. #3 Re: Ignition
    Virginia
    Actually dude with that flashing security light, it might be your bcm. What symptoms does your car exibit?
  4. #4 Re: Ignition
    May 2011
    i already replaced the pcm, the icm and now i hope not this, but everything is fine except the weird ignition switch,and if i buy a new one how do i get one with a key that gose with it?
  5. #5 Re: Ignition
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Ignition switch and cylinder and keys are different things. You just replace your ignition switch, you keep the same cylinder and keys and reuse them.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  6. #6 Re: Ignition
    Virginia
    note, i said bcm not pcm.
    Usually when your ignition switch is going out your; climate control only works on max, your headlights will turn off when clim control is on, weird relay clicking sounds inside dash, Dic flickers or goes out all together.
    Your car wont start for hours and has a security light and thats it from what youve told us. It could be the ign switch But i think the bcm is a greater possibility.
  7. #7 Re: Ignition
    May 2011
    this sounds expensive
  8. #8 Re: Ignition
    May 2011
    so if the keys still getting stuck when i get the bcm then i should changed the ingition switch?
  9. #9 Re: Ignition
    Virginia
    bcm is expensive for a dealer to do and you need a case relearn. $800.
    The ignition switch might be where your key issue is stemming from.
    If it were me I would change the ign switch regardless because they are problematic on our cars. if that doesnt take care of it go the bcm route.
    The parts by themselves are cheap.
  10. #10 Re: Ignition
    May 2011
    man thats alot of money. i tried getting the ignition switch out but the delphi pass key thing is in the way of everything, idk how to get it out its in betweek the igniton switch and the roller and tumbler were the key goes in
  11. #11 Re: Ignition
    May 2011
    anyone
  12. #12 Re: Ignition
    May 2011
    can someone please answere, were the bcm located? the trunk or under the dash
  1. Ignition Key
    By Flava601 in forum General Tech Discussion
    Last Post: 01-10-2011, 07:24 PM
  2. ignition key help
    By 03yamahar1 in forum General Tech Discussion
    Last Post: 10-10-2010, 10:06 PM
  3. Can't get my key out of the ignition!!!
    By smuj_2006 in forum General Tech Discussion
    Last Post: 06-20-2010, 08:42 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  5. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
