Thread: s/c pulley swap gone wrong
Results 1 to 17 of 17
  1. #1 s/c pulley swap gone wrong
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    so i thought i knew what i was doing when i borrowed a friends pulley.. Somehow the m8 little stud that drives into the snout is now completely stuck in the snout. There is no way to get it out. and the new pulley is halfway on the snout. What else could possibly go wrong. Any ideas?
  2. #2 Re: s/c pulley swap gone wrong
    Minnesota
    Pictures?
  3. #3 Re: s/c pulley swap gone wrong
    ill take one now
  4. #4 Re: s/c pulley swap gone wrong
    GTX Level Member colindunn's Avatar
    Aurora, IL
    The main bolt on mine (the huge one) the nut somehow got stripped onto it when my pulley was halfway on.. turned into a 2 day project between school and work and a coupld trips to home depot. with the right stuff i made a pulley tool for like les than 10 bucks lol.
    anyways, in your case.. lets see the pics
    Green Comp G. Headers. Intake. Tune. Pulley. Intercooled.
    SE fascia. Dual chrome tips. Debadge. Retrofit. Lowered.
  5. #5 Re: s/c pulley swap gone wrong
    see the nut stuck all the way inside..
  6. #6 Re: s/c pulley swap gone wrong
    im deff. going to need to make a ghetto pulley puller to make this work.. I really dont want to buy a new pulley and a snout. All because of this stupidity
  7. #7 Re: s/c pulley swap gone wrong
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    I did the same thing when I pulled my pulley out, I basically put a small Flathead in there and found a spot where the broken stud wouldnt move then I started rotate the hub around(put some penetrating oil) . Surprisingly I was able to drive it out and then needle nosed it out of there. Trust me I was also freaking out luckily enough it work out . ( the Pulley stud should be pretty loose in there ).GLWP (Good Luck with Pull )
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  8. #8 Re: s/c pulley swap gone wrong
    well the thing is, that is my new 3.5 pulley. And its halfway on. i dont want to pull it back off and try my attempt 2 lol
  9. #9 Re: s/c pulley swap gone wrong
    And i dont know what you mean by putting the flat head in there. How did you use the puller with it in there?
  10. #10 Re: s/c pulley swap gone wrong
    Jan 2009
    Quote Originally Posted by fremmy182 View Post
    I pulled the stud out .. I was supplied with 4 studs when i purchased the puller . I was lucky enough to install on last stud try lol
    I did also used a block and hammer to finish the last bit of pulley install, I know its a Big no-no but hell it worked, if you do tap it in be very careful !
  11. #11 Re: s/c pulley swap gone wrong
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    How the heck are you guys breaking these? Are these studs actually hardened? You did put a bit of oil on the shaft before you tried pressing them on? I don't remember ever having these issues when I pulled and pressed my hub on...
    Thought I would add: Drill, ez out. Probably your best bet.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  12. #12 Re: s/c pulley swap gone wrong
    im getting closer.. and im guessing the pulley has to be flush with the snout.
  13. #13 Re: s/c pulley swap gone wrong
    Typically yes..it flushes. A press would do the trick for you.
  14. #14 Re: s/c pulley swap gone wrong
  15. #15 Re: s/c pulley swap gone wrong
    Minnesota
    why no MPS?
    100% AGREE! For all the trouble, you could have pressed a hub on there and never had to do it again.
  16. #16 Re: s/c pulley swap gone wrong
    yeah i really should have done it that way.
  17. #17 Re: s/c pulley swap gone wrong
    Ahhh, I remember my 3.5" press-on.
    Better suited as a paperweight.
    I know a guy that might have one for sale...that 4thgencamarofanguy
  1. s/c pulley swap
    By fremmy182 in forum General Grand Prix Discussion
    Last Post: 03-14-2012, 04:49 PM
  2. Pulley Swap MPG's
    By MyPrixGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2012, 07:30 PM
  3. top swap pulley ?
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2011, 05:43 AM
  4. 3.8/3.4 pulley swap
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2010, 02:27 PM
