Thread: top swap pulley ?
Results 1 to 18 of 18
  1. #1 top swap pulley ?
    Nov 2010
    Atlanta Ga
    Who on here is running a top swap with a smaller pulley with no trouble.
    getting car tuned in a few weeks and would like to try a 3.4 or 3.5. Is it possible without an IC? Vs cam . Headers. Ported blower. 180 therm
  2. #2 Re: top swap pulley ?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Every car will react different, But my buddy is running a genV top swap with a 3.3 pulley. Tog headers, 180 stat, ls1 tb, and cai are only mods 0kr
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  3. #3 Re: top swap pulley ?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    ^isn't that a little low for a 3.3 gen v?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  4. #4 Re: top swap pulley ?
    How much boost is that? 10 lbs?
    Also, how much timing is he running?
    For a VS i'd try a 3.4 or 3.5.
  5. #5 Re: top swap pulley ?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    to run a 3.4 you need 42.5 injectors or bigger, and a rewire.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: top swap pulley ?
    Nov 2010
    Atlanta Ga
    I was reallyjyst thinking on using a 3.5. I wouldreally like to hit the 300 HP mark
  7. #7 Re: top swap pulley ?
    i was running a 3.4 on a top swap and i couldnt make it knock and i didnt run out of injector either.
    i was also cammed.
  8. #8 Re: top swap pulley ?
    Hagerstown,Md
    you didnt run out of injector but your were running over 100percent IDC. Which isnt a great idea.
  9. #9 Re: top swap pulley ?
  10. #10 Re: top swap pulley ?
    IPW is not IDC.
    85% IDC or higher is unideal.
  11. #11 Re: top swap pulley ?
  12. #12 Re: top swap pulley ?
    never said you cant.
    I just know 85% IDC is bad.
    Couldnt tell you what that would be in IPW.
  13. #13 Re: top swap pulley ?
    Newnan, GA
  14. #14 Re: top swap pulley ?
    why is 85% bad?
    i figured anything lower than 100% was fine, which 19 IPWs at 6000 RPM are.
  15. #15 Re: top swap pulley ?
    SWPA
    IDC's are hard to go off of too. There have been guys to show 120% IDC on there logs on a DSM or a 3000GT/Stealth. Obviously you can't go over 100% so most people try to keep it around 80-85%
  16. #16 Re: top swap pulley ?
    unless i see knock and the car starting to run lean up top, then i would never swap injectors. this is why EVERYONE needs to run a wideband on any car they want to make power with.
  17. #17 Re: top swap pulley ?
    SWPA
    Definitely agree with the wideband.
    Had I been running one earlier in my ownership I'd likely still have my modded TSi Talon.
    Running lean at 6000 rpm and 125 mph makes for bad things to happen to pistons and rings.
  18. #18 Re: top swap pulley ?
    factory wideband for more win?
  1. Supercharger Pulley Swap [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 12-04-2011, 03:16 AM
  2. 3.8/3.4 pulley swap
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2010, 02:27 PM
  3. Supercharger Pulley Swap
    By littlerobinson75 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 08:53 AM
  4. Pulley swap question ------>>> NEW GUY
    By mjm06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 01:00 AM
