Thread: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
Results 1 to 8 of 8
  1. #1 Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    May 2012
    Surrey, British Columbia, Canada
    Edit to add, in the pic below I had pressed the econo button, yes I know that disables the A/C. I had been trying to cycle the button on and off to see if that made any difference, and I just happen to leave it in that mode when I snapped the pic. I was looking for a way to manually override the auto control and force the A/C to come on.
    Ok normally something like this would not bother me, however we are in the middle of a road trip from Surrey B.C. Canada down through Washington State into Oregon and back. Then I notice the A/C which normally blows so cold that its almost too cold, has stopped working. Then I realize that the display is showing -6 outside. After a bit of reading in the Owners manual it says that below 38F the computer won't allow the compressor to turn on. FREAKING HELL. If I have read correctly the sensor is located near the front of the passenger wheel, under the car.
    Should I just replace it, or is there something else that I should look at before I yank it out and put in a new one.
    Thanks for any input.
    This is the control panel we have.
    New GTP Owner. Totally Stock. Yes I am keeping the motor in the GTP, No I am not stealing it for one of my Fiero's. Car Details; 2000 GTP 3800 S/C Auto. Bose Audio. There have been Zero mods done to the car, so starting from a clean slate.
  2. #2 Re: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    Replace the 12 dollar sensor.
    Get under the car in front and look staright up, its between the rad and inner bumper.
  3. #3 Re: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    May 2012
    Thank You FFDP, by the amount of posts you have and the fact that you have already helped me out a ton, I won't give it a 2nd thought, I'll go get a new sensor first thing in the morning.
  4. #4 Re: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    When mine went bad it would read 40º F outside when it was 80º F outside.
    So I went to the dealership and bought a new sensor and all was good.
  5. #5 Re: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    May 2012
    Just wanted to pop back in and say Thank You. They had to special order it in, but 13.99 and its installed and everything is back to perfect. An odd question, is there a way to change it from reading in Celsius to Fahrenheit? I know you can change the HUD and such with the button on the DIC, but I would really like the temp to be able to be displayed in F rather than C.
  6. #6 Re: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    Quote Originally Posted by Capt Fiero View Post
    switch on back side of unit?
  7. #7 Re: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    my regal has a E/M button, swaps everything to English or metric. not sure about the GP.
  8. #8 Re: Exterior Temp Sensor, Screwed -6 should I replace or what, long way from home.
    May 2012
    Well I have tried all the buttons, both short push and long push and have not gotten anything to change on the DIC from English to Metric. If it is a switch on the back of the unit, it'll have to wait till I get back to Canada and can play with it. Probably when I decide on the head unit.
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. Exterior Temperture Sensor reading OC
    By SNeitzel in forum General Tech Discussion
    Last Post: 10-01-2010, 11:28 AM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  4. how long and what temp in the oven to separate corner lense?
    By Zainoman in forum Off Topic Discussion
    Last Post: 03-15-2008, 02:40 AM
