Thread: Blower stuck on floor
Results 1 to 7 of 7
  1. #1 Blower stuck on floor
    May 2012
    goldsboro nc
    hey everyone
    need a little help here
    the blower in the car is stuck on floor i have a 98 GP GTP with dual digital climate control
    any ideas
  2. #2 Re: Blower stuck on floor
    May 2012
    goldsboro nc
    i was hoping that wasnt an issue with these cars i was hoping to replace the climate control head unit and viola
  3. #3 Re: Blower stuck on floor
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    I'm not entirely familiar with the workings of the W body's HVAC system but it should be vacuum controlled and if you get a vacuum leak it will default to one position and then stay there. On the old Taurus' we used to work on they would default to defroster but it's entirely possible the w body defaults to floor.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  4. #4 Re: Blower stuck on floor
    Jan 2012
    Philadelphia
    stuck on floor?
  5. #5 Re: Blower stuck on floor
    Follow the middle vacuum line on the vac tree on the blower.
    That leads to the hvac stuff.
  6. #6 Re: Blower stuck on floor
    Which then leads around by the battery, along the front bumper and to a vacuum can in the driverside fender. If that can is broken, the check valve is bad or the T by the fuse box (under hood) is bad...all those can cause this type of issue.
  7. #7 Re: Blower stuck on floor
    Quote Originally Posted by gtpeddie View Post
    stuck on floor?
    Stuck on the floor setting. It took me a min too.
  1. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  2. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  3. no a/c, no heat, no blower, key stuck
    By problems in forum General Tech Discussion
    Last Post: 08-28-2010, 07:55 PM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
