Thread: How does the GTP stack up to cars nowadays?
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 81 to 100 of 124
  1. #81 Re: How does the GTP stack up to cars nowadays?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    http://www.grandprixforums.net/guess...ile-62511.html <-- I guess if you took the slicks out of the equation it'd be in the low 13's, but still.
  2. #82 Re: How does the GTP stack up to cars nowadays?
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    so you're saying a 3.4 pulley, headers, 1.9 rockers can run low 13's....
  3. #83 Re: How does the GTP stack up to cars nowadays?
    Feb 2010
    Cleveland
    Yeah, with about 200#s of useless crap removed from the car, a little porting and a good tune.
  4. #84 Re: How does the GTP stack up to cars nowadays?
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Wow you guys all give tons of awesome info, and again thanks for all your guys opinions. This is great to know and now i just want to buy a comp G even more.
    Oh do the Chevy impala have the same weak tranny as the GTP?
  5. #85 Re: How does the GTP stack up to cars nowadays?
    Out West
    Quote Originally Posted by JDrach View Post
    If you do heads yes.
    Whine with your Cheese?
  6. #86 Re: How does the GTP stack up to cars nowadays?
    Out West
    Quote Originally Posted by SF9777 View Post
    They all have the same crappy weak transmission
  7. #87 Re: How does the GTP stack up to cars nowadays?
    Jan 2012
    Anaheim, Ca
    That sucks, if i were to get the GTP how much modding would i be able to do so that the stock tranny could still handle the power gain?
  8. #88 Re: How does the GTP stack up to cars nowadays?
    Out West
    Theoretically the transmission could go out on stock power.
    Invest in a transmission cooler.
  9. #89 Re: How does the GTP stack up to cars nowadays?
    Quote Originally Posted by addzradd View Post
    Porting heads is quite the part you keep leaving out...even in that thread.
    These heads are awful from the factory and opening them up does wonders on the flow side...like 15-20% increase?
    Yeah...expect a "common" 3.4, header/rocker car with a solid tune to crack off high 13's...maybe mid 13's with a good driver.
  10. #90 Re: How does the GTP stack up to cars nowadays?
    To answer the OP, they dont, sooo....
  11. #91 Re: How does the GTP stack up to cars nowadays?
    Quote Originally Posted by Nixon View Post
    Cooler won't "correct" the weak clutches.
  12. #92 Re: How does the GTP stack up to cars nowadays?
    Out West
    Relying on the stock in radiator cooler wont "correct" them either.
    Beat the heat with a chiller.
  13. #93 Re: How does the GTP stack up to cars nowadays?
    May 2012
    Surrey, British Columbia, Canada
    I thought the 4T65 HD trans was nearly indestructible, yikes that kinda worries me. I use to work for a radiator shop so I know a fair bit about trans coolers and such. The biggest drawback to the Radiator based coolers is the fact that they rely on engine coolant to control the heat of the trans. Which means that the trans is forced to heat up when the thermostat is closed, in a cooling system, as well as the fact that it heats the cooling system up adding extra heat to the engine. Transmission coolers are actually fairly cheap if you can find a person in the business, the markup on them from the manufacturer to the end user is actually around 300%. Our $149 cooler was only $48 bucks my cost. I no longer work their so I can't supply them to everyone, but I am sure for personal use, I can still get a good deal on one for myself.
    Side note the best thing a person can do for their trans, is take the time to pull the dipstick and smell it regularly. It will often start to smell burnt long before it turns into a dark bad colour. I say when you check your oil, or at least once a month, give your dipstick a good sniff. If it smells foul, its time to change the oil and get it clean. (yes that was suppose to be a bit dirty for you off colour people)
    New GTP Owner. Totally Stock. Yes I am keeping the motor in the GTP, No I am not stealing it for one of my Fiero's. Car Details; 2000 GTP 3800 S/C Auto. Bose Audio. There have been Zero mods done to the car, so starting from a clean slate.
  14. #94 Re: How does the GTP stack up to cars nowadays?
    Slower, Lower Delaware
    What's the difference in the GXP trans?
  15. #95 Re: How does the GTP stack up to cars nowadays?
    Out West
    Quote Originally Posted by Sudden View Post
    None
  16. #96 Re: How does the GTP stack up to cars nowadays?
    Wonder why they last a week behind a V8.
  17. #97 Re: How does the GTP stack up to cars nowadays?
    SE Level Member WhiteKnight07's Avatar
    Houston,TX
    The 3.8L has 1 advantage over most other enigines and its called low end torque. No lie, I kept up with a butt hurt Houstonian driving a turbo 911. I am pretty sure he sucked as a driver because there is no way in hell I should have kept on him. I would say the GTP will stack up against many new cars, of course depending on what you plan to do with it.
    2007 Grand Prix GT L32
    My Pontiac doesn't have to sound like a farting lawnmower to prove whats under the hood... You will know when you are watching my tail lights fade in front of you!
  18. #98 Re: How does the GTP stack up to cars nowadays?
    None
    Don't lie.
  19. #99 Re: How does the GTP stack up to cars nowadays?
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    I work at a kia dealer, Kia optima turbos may have power but they are not as practical as a gp because the interior is small and cramped feeling. Plus the exteriors still look cheap.
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  20. #100 Re: How does the GTP stack up to cars nowadays?
    Jan 2012
    Anaheim, Ca
    Ya a neighbor of mine has one that she rented for a day and she said it feels cramped. Also i found out that there is a person who parks two cars next to her with a badass looking G8 GT. Now that will own loads of cars out their, if only i had the money to get one
  1. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  2. OBX and DPT cheap ebay headers? How they stack up vs. ZZP?
    By funky4stringed in forum General Tech Discussion
    Last Post: 08-01-2010, 07:22 AM
  3. Short Stack Intercooler ????
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-22-2010, 12:24 PM
  4. zzp short stack ic
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2008, 03:53 AM
