Thread: 3 checks engine code
Results 1 to 5 of 5
  1. #1 3 checks engine code
    SE Level Member JOGTP's Avatar
    Dec 2010
    Quebec, Canada
    I have a little problem... Since the valve springs #105 and the intercooler S2 are installed i have 3 check engine codes
    P0101 : Mass Air Flow (MAF) Circuit Range/Performance Problem. I changed the MAF but the problem re-appear.
    P0131 : Oxygen O2 sensor circuit low voltage (Bank1 Sensor 1).
    P0300 : Random misfires. According to this : OBD-II Trouble Code: P0300 Random/Multiple Cylinder Misfire Detected and what my automobile mechanic it's seem there an problem with the Fuelab ajustable regulator. He told me usualy the pression is suppose to stay stable for a while after i stop my car but now after just a few minutes the pressure drop down.
    My symptoms : A lot of variation in the RPM when the engine is cold (between 0 RPM that mean the car stall and over 3000 RPM. When the engine is at normal temperature it's more between 400RPM and 1200 RPM.
    Will overkill answer me :
    I believe the MAF and o2 are on the same fuse. Is the fuse ok?
    The pressure dropping off is normal in the fuel rails. Ensure the pressure is set to 50psi with the vacuum line disconnected.
    - Will
    Where is that fuse?
  2. #2 Re: 3 checks engine code
    Dec 2010
    Quebec, Canada
  3. #3 Re: 3 checks engine code
    Dec 2010
    Quebec, Canada
  4. #4 Re: 3 checks engine code
    Dec 2010
    Quebec, Canada
  5. #5 Re: 3 checks engine code
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    no idea man. i knew you were from quebec once i read "pression" lol. but did this happen right after installing those? or gradually?
  1. engine code
    By buckslayer in forum 5.3L V8 (LS4)
    Last Post: 03-16-2011, 09:47 PM
  2. Replies: 3
    Last Post: 10-21-2009, 10:18 AM
  3. Engine Code
    By the955iman in forum General Tech Discussion
    Last Post: 04-17-2009, 04:40 PM
  4. Disabling my failing emission code checks for emissions this week
    By Quicklynx in forum General Tech Discussion
    Last Post: 03-24-2009, 07:30 PM
  5. engine code
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 04:42 PM
