Thread: car stalls when slowing down
Results 1 to 13 of 13
  1. #1 car stalls when slowing down
    Mar 2013
    Illinois
    i have a 97 se with the 3800 in it. I have been having problems with the car shutting down when coming to a stop. It appears to have a problem reaching idle after i let off gas when i come to a stop or randomly slow down. The HUD goes all crazy and then the "check guages" light comes on indicating that engine is off. I just slap into neutral, fire it up, and continue on my way. It is just an aggravating issue that i wondered if anyone had same issue.
  2. #2 Re: car stalls when slowing down
    Ohio
    where is your fuel level at when this happens?
  3. #3 Re: car stalls when slowing down
    Mar 2013
    Illinois
    it is in multiple positions, full, empty, half full. It just seems like it cant recoup when you let off the gas and eventually dies. Some days it never happens and then other days it happens 6 to 7 or more times. I have replaced fuel filter but this didnt seem to remedy it
  4. #4 Re: car stalls when slowing down
    you could try cleaning the throttle body. and the maf with maf cleaner.
    if that dont fix it im thinking crank sensor maybe, if you notice the tach drop to zero, then stall thats a crank sensor symptom.
  5. #5 Re: car stalls when slowing down
    Mar 2013
    Illinois
    generally i dont even notice it has died until the hud goes nuts. I was thinking there was a fuel delivery problem because thats just what it seems like. I have cleaned the fuel lines out and the injectors too.
  6. #6 Re: car stalls when slowing down
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Maf... had the same issue. Do yourself a favor and spend the money for a GM maf. I've heard mixed reviews about the parts store replacements, but I'll say the AutoZone one worked flawless for me. I'm certain that will fix your problem.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  7. #7 Re: car stalls when slowing down
    Mar 2013
    Illinois
    will give this a try, Thanks!
  8. #8 Re: car stalls when slowing down
    dont buy a maf unless you have a code that says the maf is bad. they are not cheap at all. used oem go for 40 ish.
  9. #9 Re: car stalls when slowing down
    Jul 2010
    Detroit
    I agree, but mine never had a MAF code.
    Ryan
  10. #10 Re: car stalls when slowing down
    Mar 2013
    Tempe, AZ
    I have this exact problem you have with my 98 GT, the shop said my Intake Manifold Gasket was bad, causing too much air to go into it, causing the stalls.
  11. #11 Re: car stalls when slowing down
    Pennsylvania
    To rule out the MAF causing the issue, unplug it and drive without it for a bit, see if the problem continues.
    If they problem magically stops, you've found the issue.
    If it continutes with the MAF unplugged, keep searching.
    Sport Edition Kv5 18x8
  12. #12 Re: car stalls when slowing down
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    Quote Originally Posted by FriboRage View Post
    This. And if it DOES go away, try the pick and pull lots for a MAF. I had to replace it on my GP at about 100k miles. That replacement was still going strong when I sold it at 204k. And I never got a MAF code that it was bad. Car just stalled when I slowed down, and if I kept giving it gas, it would keep running.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  13. #13 Re: car stalls when slowing down
    LAKEWOOD
    I have a 1999 grand prix gt 3.8L I also have a problem with my car dying, it seems to happen more when I press the gas pedle lets say because the light has turned green' but all of asudden I have to hit the brake it will usually die easier that way. I can watch the RPM's drop rite to zero and some times you can see it try to catch it's self but cant kick the RPM's up fast enough to keep running.I have had it die while I was doing 70Mph on the freeway just because I let my foot up just a little bit. There is one thing I would like to know when your car dies does the traction control light come on saying its off and what about your service engine soon light does it come on? if so then you have a bad crank position sensor" GUARENTEED"
  1. Accelerating after slowing down
    By eleedy in forum General Grand Prix Discussion
    Last Post: 10-25-2012, 02:20 PM
  2. GT Sputtering under load- only at idle and slowing down
    By Phil Becotte in forum General Tech Discussion
    Last Post: 10-24-2012, 12:04 PM
  3. Car Stalls When Slowing Down?
    By Grand in forum General Tech Discussion
    Last Post: 10-19-2012, 07:36 AM
  4. unexplained engine slowing
    By joshuascompg in forum General Grand Prix Discussion
    Last Post: 07-06-2012, 11:26 PM
  5. Vibration when slowing down
    By 03GPScottyd in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2008, 03:15 PM
