Thread: Car won't move out of park and key stuck in ignition
Results 1 to 4 of 4
  1. #1 Car won't move out of park and key stuck in ignition
    SE Level Member kc199's Avatar
    Nov 2011
    KCMO
    First this I usually do when working on my vehicles is putting them in neutral and using wheel chocks. Today I used the wheel chocks, removed the battery, unhooked everything under the hood, and pulled the engine out. Later I pulled the wheel chocks and was going to push the GP outside to clean out the engine bay. Imagine my surprise when it wouldn't move . Yep you guessed it --- I forgot to put it in neutral. I turned the key to the on position and tried to put the shifter in neutral but it wouldn't budge. The transmission is still in the vehicle and nothing was taken off of it. I did a search and saw several threads with this problem, but nothing with it happening without a battery in and everything unhooked from the engine.
    Any ideas how to get the tranny into neutral? Also any help on getting the ignition switch to turn back to get the key out (although this isn't that big of a deal right now).
    1999 GT
  2. #2 Re: Car won't move out of park and key stuck in ignition
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    my bad for not reading.. take the cable loose on the trans. move it by haand
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Car won't move out of park and key stuck in ignition
    Sep 2011
    Copperas Cove, TEXAS
    Hmm, only thing that comes to mind is the brake release switch not engaging. If you can pull up the trim around the shifter and manually pull up on the release. just my .02 I'm probably wrong LOL, but worth a try.
  4. #4 Re: Car won't move out of park and key stuck in ignition
    Nov 2011
    KCMO
    Quote Originally Posted by GTPSHAWTY View Post
    Now I feel kinda stupid...doing that never crossed my mind. It's been a long day, maybe I'll just pick back up with it tomorrow.
    1999 GT
  1. Key stuck in ignition, shifter wont move with key on...
    By robstout in forum General Tech Discussion
    Last Post: 04-06-2013, 07:45 PM
  2. shfter stuck in park!
    By gtpeddie in forum General Tech Discussion
    Last Post: 03-21-2012, 10:06 AM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
  5. Stuck in park
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2010, 10:37 AM
