Thread: 00 GTP questions
Results 1 to 20 of 24
  1. #1 00 GTP questions
    Mar 2012
    Connecticut
    Hey Guys.
    I drive a 00 Grand Prix GTP and have recently been looking to upgrade the performance of it. It seems the most common upgrades seem to be switching the supercharger pulley and putting on an intake. I was thinking about installing a 3.4 inch pulley and a K&N FIPK Air Intake but I wasn't sure if I would be able to install these without causing engine damage due to the extra power. I was also curious if there was a decent ECU program for the car. Any thoughts?
  2. #2 Re: 00 GTP questions
    Apr 2009
    Fort Worth TX
    With just a CAI and a 3.4 you might have less power and the engine might blow up. Start with the exhaust...u-bend delete and front manifold. Then go with a smaller pulley and a good tune.
    Dec 2010
    DMV
    More than likely you will break something. For those mods you'll need headers, tune, t-stat down pipe at the least I believe. Check the threads. There is a VERY USEFUL thread around that's geared towards modding your 3800.
  4. #4 Re: 00 GTP questions
    Pennsylvania
    t-stat
    NO.
  5. #5 Re: 00 GTP questions
    GTX Level Member blackflag's Avatar
    Virginia
    I really dont understand why to change the t-stat. Seems like people do it just because, am I wrong?
    The Boss Iceman6669's Avatar
    Jun 2011
    Use the search function and search for "Safely Modding Your 3800 powered car" thread... Read. Then re-read....
    2011 F-150 Yote powered
    Jun 2011
    BlackFlag.... YES you are wrong.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    WRONG....WRONG.....WRONG.
    you can easily run a 3.4 pulley with a down pipe, colder plugs, and intake, and a box tune.
    It all depends on the specific car. Why members of this board believe u need to spend thousands of dollars for a pulley is beyond me.
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  9. #9 Re: 00 GTP questions
    Mar 2012
    Connecticut
    Thanks!
  10. #10 Re: 00 GTP questions
    Mar 2012
    Connecticut
    I already did put on a Borla cat back exhaust. Where would I get the plugs and the down pipe from though. Any specific website thats a good source for the parts?
    Orange County, NY
    Zzperformance.com
  12. #12 Re: 00 GTP questions
    thousands???
    I can get to a 3.4 pulley drop for under 500 bucks.
    Headers, 200 + clamps and rtv = 225-235ish
    3.4 pulley depends on either press on or mps system. 30-100 bucks
    605's or 104's, 12 bucks.
    Tune, around 150ish depending on where you go, and could be cheaper if you know a guy with HPT.
    Changing to a cooler tstat is stupid, I never tell anyone too.
  13. #13 Re: 00 GTP questions
    Pennsylvania
    Quote Originally Posted by BlackFlag View Post
    Quote Originally Posted by Iceman6669 View Post
    No, he had it right. There is no need for him to change his thermostat.
  14. #14 Re: 00 GTP questions
    Texas
    thousands???
    When you live in a city where temps in the summer reach well above 100 degrees then changing the t-stat becomes very attractive. Especially since the factory temp sensor kicks on at an undesirable temperature.
    A downpipe, intake, and box tune will suffice for a 3.4 pulley. However, if choosing that route wouldn't it be worth spending the extra $$ and upgrading the manifolds as well.
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: 00 GTP questions
    Pennsylvania
    Quote Originally Posted by txslow6 View Post
    He's from Connecticut, not Arizona.
    Jun 2011
    This thread is full of all kinds of fail....
    Orange County, NY
    thousands???
    Lmao.... you tell people to dump hundreds of dollars for headers....yet keep the stock t-stat?
    And that 200 dollar set of headers will last maybe 2 or 3 winters.....mark my words. Plus u will be lucky to have them seal.
  18. #18 Re: 00 GTP questions
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by copgtp View Post
    What about the Pacesetters? The price seems right...are they still available? Maybe he could go with these.
    Anyone here tried these? I was thinking about putting them on my car.
  19. #19 Re: 00 GTP questions
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Cooler thermostat = cooler head temps = less chance of hot spots = reduced knock
    Of course I may be totally wrong :P
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  20. #20 Re: 00 GTP questions
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by RooK View Post
    Check this out. I wonder how this relates to our forced induction motors.
    Colder Thermostat Increase Power - Fact Or Fiction - Import Tuner Magazine
    I've seen so many different opinions on this matter. Does anyone have any data that proves one way or the other?
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. A few questions about a GXP
    By Walleyealx in forum General Tech Discussion
    Last Post: 10-08-2011, 09:34 PM
  3. New-ish GTP questions
    By Fast50dz in forum General Tech Discussion
    Last Post: 04-01-2010, 12:55 AM
  4. Two Questions
    By NorthernGT in forum Off Topic Discussion
    Last Post: 03-22-2010, 10:02 AM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
