Thread: 99 GTP Mods questions.
Results 1 to 12 of 12
  1. #1 99 GTP Mods questions.
    Nov 2010
    id
    So I have a 99 GTP. The current mods are 4" intake, 3" downpipe with cat and u bend delete, 1 degree colder spark plugs with upgraded wires, I've wrapped the crossover and will be adding a custom throttle body heat shield, wideband o2, and a custom tune.
    My goal is to get 300+ WHP. So I'd be happy with 305 WHP. I am looking into buy the VS cam from ZZP because I will be mainly driving it on the street and maybe once in a blue moon take it to the track. My list of purchases are as follows.
    * VS cam
    * New Springs, Seals, and locks. Going with stock or 85lb springs.
    * 3.4 modular pulley
    * New custom tune
    My real question is should I purchase 42.5# injectors with this setup or will the stock 33# handle them, and should this break the 300 WHP mark?
    If this is already a thread sorry for reposting.
  2. #2 Re: 99 GTP Mods questions.
    Kemmerer, Wyoming
    I think you can get 305 without doing a cam. to my knowledge a full exhaust and intake with a gen 5 supercharger and 1.9 rockers with a 3.4" supercharger pulley will get you there.
  3. #3 Re: 99 GTP Mods questions.
    Wont even come close to 300whp, maybe 250........maybe....... with what you have listed.
    You need flow mods to run a cam.
    Buy some headers, skip wrapping the crossover and screw the tb heat shield, the blower super heats the air anyway, you cant stop it.
    So here is how I would do it.
    Headers
    vs cam
    prolly L76 springs
    Ported blower
    3.4 pulley
    AL 104's
    and a Wideband Tune
    You might get away with stock injectors still, you would just have to see.
    Even with those mods, you may not even get 300 WHP more around 270-280 whp, and when you get that high, transmisson failure rate goes way up.
    Ohio
    Stock l67 injectors are 36 lbs btw
  5. #5 Re: 99 GTP Mods questions.
    Nov 2010
    id
    Quote Originally Posted by 99pgpgt View Post
    Everywhere I've been has posted that they are 33 lbs stock. Plus I've replaced mine and I purchased new 33# injectors. Should have bought larger but was hurting for cash.
  6. #6 Re: 99 GTP Mods questions.
    Nov 2010
    id
    I agree with not reaching 300 WHP it was a goal that I'm shooting for and will continue to hunt it down if I don'r reach it with this upgrade. So yes I agree I will most likely land in the 270-290 area. Thanks for the transmission warning. It was replaced approximatly 15,000 miles ago so should be ok because I rarely race or go to the strip.
    My main areas where I was having issues on proper information were injectors being able to hold up and the valve springs. I've read a few times but actually having someone say it helps that injector sizing really just depends on the car. So I'll just have to hope mine work or go with a mild tune and save up for new ones after the build. As for the L76 springs I was looking at upgraded springs so I avoid valve float at all possible. I have one question and that is will the L76 springs work with stock retainers or will I need new ones?
  7. #7 Re: 99 GTP Mods questions.
    Nov 2010
    id
    Quote Originally Posted by johntremell View Post
    I am looking at avoiding the Gen V supercharger for now as I am a broke college student. I may purchase it later in life when I can afford to really add performance. Thank you for your reply.
  8. #8 Re: 99 GTP Mods questions.
    GT Level Member mkyota1's Avatar
    Daytona, florida
    You will need new retiners to run the l76 springs.
  9. #9 Re: 99 GTP Mods questions.
    Worthless Troll
    You will need an intercooler and a much smaller pulley to reach 300whp with the VS cam. Preferably a stage 2 intercooler.
  10. #10 Re: 99 GTP Mods questions.
    new britain, ct
    if youre going that deep into the engine, you might as well do a cam. rockers dont even compare.
    07 Black GXP.
  11. #11 Re: 99 GTP Mods questions.
    Out West
    indeed.
    at least do a VS cam
    Whine with your Cheese?
    Quote Originally Posted by newbiegtp View Post
    A cam is 800-900 if you do the install yourself.
    Intercooler its well over a grand. You'll still want a larger tb by that point.
    that's another 300.
    Gen v is only another 300.
    Use l76 springs and ls1 retainers.
    All in all the comment I quoted its funny.
    You'll need injectors but I don't recommend the Lucas 42.5's.
    Get 60's or better ~40's.
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. Questions about Transmission Cooling, Worth it on stock or wait until mods performed?
    By Mad Max in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2012, 02:28 PM
  3. Questions on some mods
    By Everblades2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2010, 06:35 PM
  4. Future mods questions
    By nascartech in forum Introductions/Noob Questions
    Last Post: 03-30-2009, 02:49 PM
  5. My list of possible upcoming mods. I have some questions :)
    By Freebeer187 in forum General Tech Discussion
    Last Post: 07-30-2008, 11:02 PM
