Thread: GTP: A few Coolant problems
Results 1 to 20 of 25
  1. #1 GTP: A few Coolant problems
    LA
    98 Grand Prix GTP
    First problem: Coolant leak at what looks where the throttle body meets the supercharger housing. Now I just removed the throttle body to clean everything out. I didn't notice a leak before that. I assume that I need to change the gasket. However, should there be coolant in that area even with a gasket? I thought only air should be passing through there? If there is another leak behind the throttle body how do I tell where it's coming from and would I be able to change the gaskets of the supercharger or would I have to repair/replace?
    Second problem: Just yesterday my car started overheating. It was also the day I removed the throttlebody and noticed that leak so it could be related. However I'm getting no heat and a cold radiator. Hot upper hose and relatively (for being next to unshielded headers) cold lower hose. From what I know these are classic signs of a blocked cooling system. So i just back flushed until i got clear water from both top and bottom of the radiator. The fact that there was water coming from both sides of the radiator leads me to believe there is nothing blocking it. I have a relatively new 160* Tstat also. So I go to refill it and I can only get in about half a gallon of coolant before the radiator starts overflowing. I drain it again, close the cap and pop the Tstat housing and try filling from there but get the same results, I can only get about half to 3/4 a gallon before it starts backing up on me. Unlike the leak I always noticed this problem. I just thought I was misjudging how much coolant I had but after flushing I would think I would be able to get atleast 2 gallons in there
    Any ideas?
  2. #2 Re: GTP: A few Coolant problems
    LA
    I have searched the forum for the answer but only saw answers that applied to NA grand prixs, and since the SC replaces the upper and lower IM I need an answer that is specific to the GTP
  3. #3 Re: GTP: A few Coolant problems
    The TB has a coolant passage in it to make sure the tb plate does not freeze in the winter. Get a new gasket for that.
    160º is WAY too cold, get a OEM 195º, you dont need to run anything cooler than that.
    So you've pulled the lower rad hose and drain all the coolant from the rad and half the motor and can still only get 1 gallon in there?
    I would just fill the LIM with coolant, bolt the thermo housing back on, fill the rad, run the car with the bleed screw open to vent any air, and keep adding coolant as needed. Bleed till alll the air is out and close up the cooling system and shut the car off, or take it for a drive
  4. #4 Re: GTP: A few Coolant problems
    LA
    sorry I meant 180 Tstat not 160
  5. #5 Re: GTP: A few Coolant problems
    LA
    I am running a few mods and a 180 was suggested over a 195
    I never pulled the lower rad hose I let it drain from the drain plug...should I have or would that suffice?
  6. #6 Re: GTP: A few Coolant problems
    same thing. I never do the drain plug because they break all the time.
  7. #7 Re: GTP: A few Coolant problems
    LA
    also the gasket you are referring to, that would go between the TB and the SC? Or somewhere else on the TB?
  8. #8 Re: GTP: A few Coolant problems
    between the TB and blower.
    Clean up the surfaces and put a new gasket in there.
  9. #9 Re: GTP: A few Coolant problems
    LA
    Alright, I appreciate the fast help. If autzone has it Ill do this tonight by candle light. If not ill try it early in the AM
  10. #10 Re: GTP: A few Coolant problems
    LA
    One more question. Since this gasket is failing. Is the coolant leaking internally also? Am I getting coolant sucked into my blower? I only ask to know if it's OK to drive to the dealership in the morning or should I just let it sit till I replace the gasket. Last thing I want is a hydro-lock situation
  11. #11 Re: GTP: A few Coolant problems
    It shouldnt go into the motor, but its posssible it could.
    Just replace the gasket, fill with coolant and start her up and bleed it and all should be good.
    Why's it going to the dealer?
  12. #12 Re: GTP: A few Coolant problems
    LA
    I can't find the part listed at autozone and I don't have the time to wait for it to be delivered. So to the dealership i go.
  13. #13 Re: GTP: A few Coolant problems
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Idk if anyone on here has experinced the issue but thermostats are cheap and can come bad. Not likely but possible. Also, did u just run water through the rad or through the motor too? Cuz u werent specific. Probably should've ran water through ur heater core hoses too
  14. #14 Re: GTP: A few Coolant problems
    LA
    Quote Originally Posted by bps02gtp View Post
    I backflushed, which means i flushed through the inlet hose and it came out of both sides of the radiator.
    As for the thermostat, I hadn't checked it, and I should check to see if it opens. But i figured since the top hose was hot there was coolant going through there
  15. #15 Re: GTP: A few Coolant problems
    Dealership isn't likely to have it either. Call ahead.
    As for the local places having it... they should be able to have it same or next day.
  16. #16 Re: GTP: A few Coolant problems
    LA
    No one had it so I went with closest GM place that would let me next day order over the phone. I should have it installed by tomorrow afternoon and I'll update on how it's running
  17. #17 Re: GTP: A few Coolant problems
    LA
    Alright...pretty big f*** up
    I repaired everything, and the car was running fine. I went to take my wife to work and it started overheating a bit. We were close and running a little late so I tried to tough it out...bad move. It got close to the red fairly quickly so I immediately pulled over and popped the hood. Apparently I hadn't fastened the inlet hose back tight enough and it blew. I had white smoke or steam coming from my dipstick and when i opened the oil fill tank there was sizzling/bubbling inside. And the coup de gras, bubbling coming from around where the fuel injection lines meet the crank case. So what do you think I have screwed up and how much of my money and time will I have to forfeit to fix it?
    RIP
  18. #18 Re: GTP: A few Coolant problems
    LA
    After it cooled down and i replaced the hose and put some more coolant in, i drove it and it stuttered badly at idle everytime i stopped. After a while it stopped. I still wasn't getting any hot air from the heater though.
    RIP
  19. #19 Re: GTP: A few Coolant problems
    Did you bleed it right?
  20. #20 Re: GTP: A few Coolant problems
    LA
    yeah, I opened up the tstat valve and ran it to operating temp until coolant started coming out.
    RIP
  1. Installing the Coolant Temperature Sensor Problems
    By ZackN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2011, 04:39 PM
  2. Coolant problems
    By sparty16 in forum General Tech Discussion
    Last Post: 02-25-2011, 12:03 PM
  3. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
  4. coolant fan problems
    By jpopdallas in forum General Tech Discussion
    Last Post: 04-16-2009, 04:32 AM
  5. Vehicle problems - won't run, coolant leak
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:17 AM
