Thread: GTP: A few Coolant problems
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: GTP: A few Coolant problems
    LA
    just to clarify when I said "it stopped", I meant the stuttering stopped, and the car ran smoothly again, but I still wasn't getting hot air and I had to stop a couple of times when the temp gauge when past half-way
    RIP
  2. #22 Re: GTP: A few Coolant problems
    LA
    just started it up again...stuttered for a bit like a vacuum leak then revved high on its own and smoothed out for the most part. Still no hot air. Inlet hose is cold, bottom radiator hose is cold, top hose is hot. Maybe bleed it again since it was running with the hose off?
    RIP
  3. #23 Re: GTP: A few Coolant problems
    Id try to bleed it again.
    Check all vacuum lines for rips or breaks and see what you can find.
    Try cleaning the throttle body and MAF aswell, those could cause the small bog, then it rights itself.
  4. #24 Re: GTP: A few Coolant problems
    LA
    well i just cleaned the TB when i changed the gasket I guess I could hit the MAF again...i did just clean it though. Let me try to see if there are any trapped air bubbles
    RIP
  5. #25 Re: GTP: A few Coolant problems
    LA
    Ok everything is running alright...still getting stuttering like there is a vacuum leak or something going on with the fuel system but it only seems to be happen within 5 minutes of starting, after warming up, I don't notice anything. It can get very close to stalling but won't stall no matter what I do. But the cooling system is working so i'm happy about that.
    RIP
  1. Installing the Coolant Temperature Sensor Problems
    By ZackN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2011, 04:39 PM
  2. Coolant problems
    By sparty16 in forum General Tech Discussion
    Last Post: 02-25-2011, 12:03 PM
  3. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
  4. coolant fan problems
    By jpopdallas in forum General Tech Discussion
    Last Post: 04-16-2009, 04:32 AM
  5. Vehicle problems - won't run, coolant leak
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:17 AM
