Thread: I'm Stumped-Needing Advice
Results 1 to 5 of 5
  1. #1 I'm Stumped-Needing Advice
    Jul 2011
    midwest
    Got a '97 GP with 185,000 miles. Has a rough idle and sputters/shakes while accelerating-causing the car to vibrate. I just changed the spark plugs and wires and nothing has changed. It is very consistent-has a steady beat. I went to change the fuel filter, but after I tried as hard as I could pull-I feared ruining the line and quit. So the fuel filter didnt get replaced-I dont think that is whats wrong anyway. The motor also is pulling air through the oil cap. When I pull the oil cap off, it takes a deep breath through the oil fill cap and the engine almost dies then takes back off again. I am stumped and any help would be great.
    Thanks
  2. #2 Re: I'm Stumped-Needing Advice
    Charles City, IA
    Get a new pcv valve
    SMGPFC Two Nipple General
  3. #3 Re: I'm Stumped-Needing Advice
    Jul 2011
    midwest
    Where is the pvc valve located? I will get a new one and try that, but I would like to visually find it and look at it to see if there is anything visually wrong with it. Also I like to take the old one with me to the parts store to make sure I get the right one. Is there any tricks to installing the PVC valve?
    Thanks
  4. #4 Re: I'm Stumped-Needing Advice
    Jul 2011
    midwest
    Put in a new pcv valve and got a new mass flow sensor-neither changed anything. Anyone have any other ideas-im thinking cat convertor. Not much preasure coming from tail pipes.
  5. #5 Re: I'm Stumped-Needing Advice
    Jun 2011
    Detroit, MI
    Possibly the cat, change the air filter, if you haven't in a while. Maybe your maf is bad? idk........
    iLoveSpade
  1. Ok Im stumped...PLEASE HELP!!
    By sinceregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2010, 06:27 PM
  2. Stumped
    By Vern in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 10:45 AM
  3. stumped
    By lucidGTP307 in forum General Tech Discussion
    Last Post: 03-16-2009, 09:36 PM
  4. Stumped
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 05:12 PM
  5. Stumped
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2009, 09:34 PM
