Trans tube was not an issue
SSAC's. I haven't had any issues with mine and they are 175 bux now vs the 350 I gave for them. Turbo Kits, Turbo Manifolds, Import Performance Products, SSAutochrome Inc.
Finished install (Pacesetters) and wasn't nearly as bad as made out to be. Easy actually, no dip stick issue, no need to take TB off, engine mounts or anything. Just some patience and a steady hand...
Had small tick, my fault, didn't tighten rear header enough. Retightened and all was good. Used band clamps and Copper RTV on the Y fitting/collector and tightened those like crazy!
Seems though that they do come down a bit under car (ground clearance) but its something I didn't pay attention to before ripping out the old stock exhaust. Are they like that or is it just me? Lolz...
the SLP type headers are pretty low hanging. 3" lower then the trans pan
yeah never had an issue either and i drive down a dirt road to get to work
im lowered and i have scrapped it once... but it was a bad up hill exit from BK that i took straight on... if i would have taken it on a angle i would have been fine. either way i think when i do my topswap i will find an exhaust shop to replace the flex and remove about 1/2 to 1" of distance off the rear header to raise the U bend.
Cut some of the hangers off to give a little more clearance, still think it looks a bit low, but there's not much room above the collector flange anyway. Here's a pic... lol, I'll get a better pic tomorrow with the sunlight![]()
