Thread: ZZP 8 Rib SFI Balancer remove
Results 1 to 4 of 4
  1. #1 ZZP 8 Rib SFI Balancer remove
    Jun 2018
    Schweiz
    Hi all
    I have the ZZP 8 Rib SFI Balancer.
    My question:
    How can I remove them if the crankshaft sensor is broken?
    thanks for your answers
  2. #2 Re: ZZP 8 Rib SFI Balancer remove
    St. Louis
    Not sure I follow you. If you are looking to remove the 8 rib SFI balancer to replace the crank sensor then this is what I found on ZZP's page- If You Need To Remove This The Balancer It Only Uses 2 Bolts And They Are Larger Sized Bolts Than The Stock Balancer. They Are Standard Not Metric.
  3. #3 Re: ZZP 8 Rib SFI Balancer remove
    Jun 2018
    Schweiz
    Yes I red it but where are these bolts or where to put em in in the balancer?
    This is the balancer:
    ​The holes are only holes where can I put a screw in??
  4. #4 Re: ZZP 8 Rib SFI Balancer remove
    St. Louis
    I'd hit up ZZP and see what they say. If I run across any info I'll post it.
  1. SFI balancer
    By gambler87 in forum Wanted To Buy - Parts
    Last Post: 01-16-2016, 02:51 PM
  2. Suggestions. L67 balancer or use zzp ss pulleys wih l36 balancer??
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2012, 02:45 PM
  3. Replies: 1
    Last Post: 07-30-2012, 05:28 PM
  4. Who has a zzp 8 rib balancer
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 07:08 AM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
