Thread: Sway bar link installation issue
Results 1 to 11 of 11
  1. #1 Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    01 Grand Prix......
    I hit my wheel, bent control arm and inner tie rod end. Got the inner tie rod end on, and lower control arm on.
    I'm trying to install the sway bar link, and the sway bar is too close to the lower control arm to get my sway bar link bushings in place.
    I started to loosen the two bolts holding the sway bar itself to the sub frame but the front one (of course, the hardest one to get at)
    Is fighting me the whole way out.
    I wasn't going to replace the sway bar link on the other side at this time.
    But do you think I need to cut the sway bar link off of the other side so the sway bar will swing up enough to install the 1st. side?
    I can't see where the sway bar might have also bent, causing my issue, because the sway bar where the link mounts, and the mounting boss on the control arm are still in line.
  2. #2 Re: Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    Maybe there is not too much activity over here any longer?
    I guess I might have to just cut that other side off and see what happens I haven't tried to do anything with it yet since I posted.
  3. #3 Re: Sway bar link installation issue
    St. Louis
    Chats
    May have to let the control arm droop down a bit to get the links in place if you have a jackstand under it. If you hit the wheel hard enough to bend all of that they swaybar may be shoved over some. If you haven't unbolted it see if there are any clean marks on the bar where it mounts at the bushings that may indicate it moved over. Could possibly be more bent up things that were overlooked.
  4. #4 Re: Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    I know. I un-did the other side and got the 1st side on.
    I didn't tighten the first side link yet, it's just started.
    Tightened the other side
    (good side)
    With the control arms hanging
    Down it ( the link kit) looks
    A bit closer to the axle, so I think it's tweaked slightly.
    I'll have to tighten the link kit and set it on the ground, or put
    a jack under the control arms, making it about at ~ride height
    And see what it looks like.
    I was hurting too bad to continue today.
    I'm sure hoping to NOT have to change the sway bar too.
    Maybe I can tweak it back slightly somehow if need be.
    Thanks for the reply.
    I'll let yin's know.
    Hope I made sense, I'm tired.
  5. #5 Re: Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    Looks like everything is clearing ok, with the sway bar link end's tightened, when jacked up under the control arm, and also wheel on and let down on the ground.
    Link looks slightly closer (forward towards axle) on the side I had to work on,
    than the passenger side, but it's clearing ok.
    Yes, sway bar may be treated slightly, but all seems ok, visually and also on road test.
    Thank you for the replies.
  6. #6 Re: Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    Quote Originally Posted by mrbreezeet1 View Post
    (Sway bar may be tweaked, not treated)
    I don't see an edit option.
  7. #7 Re: Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    That car is driving real nice. I still have to do the lower control arm on the right side and I found some play in the right side outer tie rod end how we replacing those as well probably next week.
    I hope the Detroit Axle lower control arms hold up for me.
    Sent from my G80 using Tapatalk
  8. #8 Re: Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    Did the lower control arm, and the outer tie rod end on the right side yesterday.
    Got a little careless though, and pulled on the axle a little too much, and pulled the inner boot off the inner CV joint.
    Tried to straighten the crimp on the oetiker style clamp, but couldn't get it open enough.
    Put a long zip tie around the boot for now.
    Anyone have a link to a good replacement oetiker style clamp?
    Most of the oetiker style clamps on Amazon have poor reviews.
    My research indicates that a lot of guys just use a zip tie.
    Do you guys think the zip tie would hold up?
  9. #9 Re: Sway bar link installation issue
    GT Level Member mainecrab's Avatar
    Feb 2008
    Chats
    The zip tie will hold. I tried my hardest to even use the same clamps, bought the snippers. Was a waste. The zip tie proved to be the best method. I had two put together.
  10. Likes mrbreezeet1 liked this post
  11. #10 Re: Sway bar link installation issue
    Jan 2021
    Ohio
    Chats
    Quote Originally Posted by mainecrab View Post
    Sorry I just saw this I guess there's no provisions for notifications, and I've been reading the archives lately.
    Yes, so far so good the zip tie is holding up thanks again.
  12. #11 Re: Sway bar link installation issue
    Feb 2008
    Chats
    Glad to hear. Yes is nice to get into a new forum or even one you haven't had to use in a while and read back through threads and find something new.
  13. Thanks mrbreezeet1 thanked for this post
  1. ZZP Control arm sway bar link mod
    By 91parkave in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2015, 02:18 PM
  2. Need help with a rear sway bar link on a GXP
    By Boarderx3120 in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2013, 04:50 PM
  3. Need help with a rear sway bar link on a GXP
    By Boarderx3120 in forum How To Write-Ups/Tech Tips
  4. Sway Bar Link
    By gemax in forum Brakes/Suspension/Chassis
    Last Post: 04-02-2013, 05:54 PM
  5. sway bar end link issue
    By jspangler22 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2011, 07:53 PM
