Thread: ZZP Control arm sway bar link mod
Results 1 to 1 of 1
Threaded View
  1. #1 ZZP Control arm sway bar link mod
    Arizona
    Well for guys with these control arms, we all know your sway bar will not be level due to the provided spherical rod bearing height, maybe if your dway has been flipped you might be able to achieve it being level. However itsnt a practical solution for everybody, but for 12 bucks and a trip to ACE hardware you can use 1/2 hook bolts that be adjusted to whatever height needed. All you need to do cut the hook portion and press it out or drill it out, and cut the thread to desired height.
  1. 2002 gtp broken sway bar end link
    By OcalaGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-27-2014, 11:55 PM
  2. Need help with a rear sway bar link on a GXP
    By Boarderx3120 in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2013, 04:50 PM
  3. Need help with a rear sway bar link on a GXP
    By Boarderx3120 in forum How To Write-Ups/Tech Tips
  4. Sway Bar Link
    By gemax in forum Brakes/Suspension/Chassis
    Last Post: 04-02-2013, 05:54 PM
  5. sway bar end link issue
    By jspangler22 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2011, 07:53 PM
