Thread: need some info and help.
Results 1 to 14 of 14
  1. #1 need some info and help.
    Jan 2016
    VA
    hey guys,
    i have a 95 pontiac grand prix with 3.1 engine.
    this just started out of the blue,
    problem
    the car started to miss fire under load, like if you hold the brake and give it gas it will miss pretty bad like shake the car and you can hear it out the tail pipe. also it only dose this under load, once going its find untill (2nd problem) you hit 2nd gear and around about 3k rpm it will lose power, like you can feel and see it on the tach struggle to gain speed,it will gain speed but you can feel and see somthing is holding it back
    i cant pull codes,never could. anyone got any tips or ideas?
  2. #2 Re: need some info and help.
    St. Louis
    when's the last time it had new plugs and wires? How many miles are on the car?
  3. #3 Re: need some info and help.
    Mar 2018
    NY
    When was the last time you changed your spark plugs & wires? That's the first thing that comes to my mind
  4. #4 Re: need some info and help.
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by digitalgpbandit View Post
    and fuel filter
    08 grand prix NA3800
  5. #5 Re: need some info and help.
    Jan 2016
    VA
    dang it, the plugs and fuel filter didnt help.
  6. #6 Re: need some info and help.
    GT Level Member mguzzo's Avatar
    Buffalo NY
    clogged cat?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. #7 Re: need some info and help.
    Jan 2016
    VA
    i just came in from replaceing the sparkplugs and fuel filter.
    how can you test if the cat is bad?
  8. #8 Re: need some info and help.
    Jan 2016
    VA
    sparkplugs and wires,fuel filter, and tps didnt work. lol
  9. #9 Re: need some info and help.
    Apr 2015
    Columbus, OH
    You really need codes. Does check engine light blink? Check fuse for obd2 port. Are all cylinders firing? On cold start you can carefully feel which ones are warming up.
    Top Swapped 01 Imp
  10. #10 Re: need some info and help.
    Jan 2016
    VA
    Quote Originally Posted by bandook View Post
    cant check codes, its the obd 1.5, no body has one around where im at
  11. #11 Re: need some info and help.
    May 2020
    Pittsburgh
    Typically a bad cat will get worse as it gets hotter. You can also tell by the temperature difference before and after the cat after running 5min or so. It should be within roughly 20*, from inlet to outlet. If it's plugged it'll be substantially hotter on inlet side.
  12. #12 Re: need some info and help.
    St. Louis
    Well, if you want to invest some money in a scanner I know my older Actron will read OBD 1.5 codes. In fact I bought it for that exact reason so I could scan my 95 Bonneville. I can give you the model# if you want to look for one. Works on OBD II stuff to up until the canbus stuff came into play.
  13. #13 Re: need some info and help.
    Jan 2016
    VA
    Quote Originally Posted by FordMan77 View Post
    yes please,
  14. #14 Re: need some info and help.
    St. Louis
    Actron CP9145 Super AutoScanner.
    I would verify that it will work on the GP but I don't see why not. I just plugged mine into my 00 GP and set it to read codes for a 95 GP with the 3.1 and 4t60 trans and it was ready to go. In fact there were 3 options for a 95 GP it listed.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. first days!!! any info of good info
    By 97gtp83boy in forum Introductions/Noob Questions
    Last Post: 02-24-2013, 02:17 AM
  3. Info please?
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 02-21-2013, 01:40 AM
  4. Does anyone know more info about the HV3?
    By JESSEGOTTA GP GT in forum Off Topic Discussion
    Last Post: 01-12-2010, 01:48 PM
  5. Need some info on LCA's
    By SyntheticShield in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2008, 06:34 PM
