Thread: Performance Shift Button
Results 1 to 11 of 11
  1. #1 Re: Performance Shift Button
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by GrandPrixGT1 View Post
    After 2001 performance shift was locked in the PCM even if it was unlocked the tables were the same. It was just a light that came on. I bought the last new performance shift shift knob GM had left. It’s pin 23 in the PCM bottom connector I believe. I had mine “custom” tuned so the shift pressures are noticeably different as well as shift points when you start digging into the throttle. I wanted the switch because it’s a daily driver and I’ve noticed when the transmission is cold it shifts pretty hard so I leave it on the stock tables until it warms up a bit. And it’s nice to have anyway if you just want to drive around on stock shift tables.
    Interesting. So you're saying that you noticed a difference and all you have to do is have the pcm tuned to "unblock" these tables? I do notice that the shift is pretty firm because of the transgo shift kit. What all was involved?
  2. #2 Re: Performance Shift Button
    SE Level Member GrandPrixGT1's Avatar
    Jan 2017
    Mount Airy, MD
    Quote Originally Posted by wstefan20 View Post
    Yes you'll need to get the PCM tuned. The transgo is a mechanical thing so you'll always feel that. Ground Pin 21 on the top connector I believe is where it is and wire that into the cabin with a switch to ground. Verify that your switch is working with a multimeter and then your good after you get it tuned. Im pretty sure its the top connector id have to look at mine to see where I have it.
  1. Replies: 214
    Last Post: 09-08-2015, 08:59 PM
  2. Performance shift button
    By Zzp98gs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-07-2015, 02:57 PM
  3. my car wont shift from park without pressing relese button
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-12-2012, 12:49 AM
  4. perf shift not working (not the button)
    By lisas1998gtp in forum General Tech Discussion
    Last Post: 04-23-2010, 10:55 PM
  5. ?? about performance shift button
    By DesQ27 in forum Off Topic Discussion
    Last Post: 06-29-2008, 01:13 PM
