Thread: Stalling right after start up
Results 1 to 11 of 11
  1. #1 Stalling right after start up
    Nov 2009
    California
    This is a very annoying problem- all stock engine on 2001, 140k miles. After car has warmed up and then shut off, sometimes it will stall immediately after the next start. Not all the time though. Engine runs fine otherwise, just slightly rough due to age. I recently replaced the MAF sensor, as cleaning the old one did not work. Could this be an injector problem or, worse, fuel pump possibly? Fuel filter? Filter was replaced at 84K. Also one time, the car stalled while just idling at a traffic light. The weird thing was, all electrical power was lost for about 15 or 20 minutes.(wife had the car at the time) then it decided to start after electrical came back on board by itself.Really? Any thoughts appreciated... Chumely
  2. #2 Re: Stalling right after start up
    Ever cleaned the throttle body itself and the IAC passage in the throttle body?
    If it's never been done it's likelt to be caked in black carbon build up. It's a free thing to do to see if it helps.
  3. #3 Re: Stalling right after start up
    also does it smell like rotten eggs inside the car? if so, could be a clogged cat converter
  4. #4 Re: Stalling right after start up
    SE Level Member Jammonz's Avatar
    Sep 2017
    Missouri
    QUOTE: "Also one time, the car stalled while just idling at a traffic light. The weird thing was, all electrical power was lost for about 15 or 20 minutes.(wife had the car at the time) then it decided to start after electrical came back on board by itself.Really? Any thoughts appreciated... Chumely"
    This part sounds familiar..........possible starter switch on the steering column (or wherever they put it now) that is connected to your key switch plunger? could have a short or bad connection........just a thought!!!!??? It sounds very familiar and it's been awhile for me since I worked on any car electronics, sooooooooooooo.........????
    "We.......over 60......are like old trees! Our Limbs may be Wilting and falling off, but our BARK is still there!!"
  5. #5 Re: Stalling right after start up
    St. Louis
    Are both the battery connections clean and tight? Even a slightly loose cable can cause weird issues. If you can move the cable by hand then it's too loose. Also check the grounds at the trans. bellhousing.
  6. #6 Re: Stalling right after start up
    Sep 2017
    Missouri
    Sorry Chumely.........I misread your statement about the POWER coming back, NOT the starter restarting on it's own! THAT would be an eerie feeling to have that happen, LOL!! Sorry!
    My answer was based on a true story and could never figure why the plunger kept sticking!
    Yours sounds like what FordMan says......I agree with him on this one! Ground problems cause some irritating problems for sure!
  7. #7 Re: Stalling right after start up
    Quincy, Mass
    I too agree with fordman, my wife’s car had similar issues with start up and stalling right away. Loose connections to the battery was the problem.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Stalling right after start up
    Sep 2017
    I had similar issues. I cleaned the throttle body and that totally fixed it.
    Sent from my SM-G900V using Tapatalk
  9. #9 Re: Stalling right after start up
    Nov 2009
    California
    Is cleaning the throttle body very difficult or involved as far as taking things apart?
  10. #10 Re: Stalling right after start up
    Sep 2017
    Missouri
    "The weird thing was, all electrical power was lost for about 15 or 20 minutes.(wife had the car at the time) then it decided to start after electrical came back on board by itself.Really? Any thoughts appreciated... Chumely"
    Remember.......this is the key to the problem or else you have 2 of them at once......I'm betting you are going to fix the electrical (battery connections) and this will either fix the problem or at least lead to what is!!!
    Amon
  11. #11 Re: Stalling right after start up
    Sep 2017
    Quote Originally Posted by chumley View Post
    It was easy on my '04. there several vids on youtube. Pretty sure there are similarities to your '01.
  1. Stalling on start
    By Jcinor in forum Engine
    Last Post: 08-18-2014, 11:47 AM
  2. Cold Start Stalling
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 05-20-2014, 10:25 PM
  3. Overkill PCM now Stalling rough start
    By kyleinkman in forum PCM Tuning
    Last Post: 10-25-2011, 07:26 PM
  4. Rough Start/Stalling Issue
    By Bigg Dogg in forum General Tech Discussion
    Last Post: 08-18-2011, 07:08 AM
  5. 97 GTP - Rough idle, stalling after start?
    By Psyk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:08 PM
