Thread: Oil Extraction/Fujimoto\drain plug
Results 1 to 6 of 6
  1. #1 Oil Extraction/Fujimoto\drain plug
    Mar 2017
    Internet
    Guys..
    I think I've changed the way I do oil changes and likely the way I drain most of the oil from a transmission. This is after years and years of doing so.
    Drain plug:
    It's easy, right? Pull the car on ramps, pull out the pan and drain away. Transmission just takes a little finesse and a big enough pan. Never had a problem or stripped plug etc. Been doing it this way for years. Sure there's some splashing or a breeze blows that last little hair of the oil outside the pan. Nothing a little brake cleaner can't clean up. Simple, effective and works.
    Fujimoto:
    Never personally installed one. It's a valve that you install where the drain plug on the oil pan is located. You hook on a hose, open the valve and poof... draining. To me it's maybe a smidge easier than turning a wrench on the drain plug. Might be a little cleaner, but you know you are going to have a drip or two when you pull the hose off it.
    Extractor:
    Never could see how stuffing a hose down the oil dipstick tube was going to get all the oil out. Or at least more than pulling the plug. Since I want to do a change on my boat (inboard), I picked up an extractor yesterday. Needed a change on the car as well and decided for S&G's to use the Harbor Freight extractor (Holt). Holy moses.. that damn thing sucked every drop out of the pan. . After one oil change, I am rethinking how I do oil changes. I'd also use this thing to slurp out trans fluid before dropping a pan as well just to make it easier and cleaner. It was a super clean, super easy (didn't even put on gloves) oil change. I am rather impressed and have changed my thoughts on these extractors.
    Hope this helps some of you that don't have a garage or place to do much work on your car. And.... in my Audi, the filter is on top so that may effect how others feel about extracting vs crawling under. Because if I had to do a filter on a 3.8, I'd still need to crawl under.
  2. #2 Re: Oil Extraction/Fujimoto\drain plug
    I used those all the time when things are known to get messy or I didn't want to drop the pan.
    I'd suck out all the diff fluid or transmission fluid, measure it and dump what I sucked out back in. The pump kind or air powered ones are legit.
    Moral of the story is, I am lazy and I do things how I want.
  3. #3 Re: Oil Extraction/Fujimoto\drain plug
    Mar 2017
    Internet
    That's the one I picked up. Looks like mightyvac has one that can pump fluid back out of it's res as well. I'm happy at the moment with being able to siphon only. Gimme 5 minutes lol
  4. #4 Re: Oil Extraction/Fujimoto\drain plug
    i had one back in the day for changing the oil in my boat with a 305 inboard. theres no other way to get the oil out on some boats. if you were to get a pan under the engine, good luck getting it back up and out with out spilling all over.
  5. #5 Re: Oil Extraction/Fujimoto\drain plug
    and these suck out the oil deals work much better on warm to hot oil. cold it will take a long ass time to suck it all out.
  6. #6 Re: Oil Extraction/Fujimoto\drain plug
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  1. Oil drain plug size
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2012, 12:54 PM
  2. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  3. Drain Plug in Trans pan
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 11:32 AM
  4. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  5. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
